We need some assistance on how to handle an issue we are seeing with our custom label program. I have created a ticket with EpicCare, directed to Professional Services, reached out to our CAM. Nothing yet.
We have been migrating users to Kinetic, and we rebuilt our custom label program in Kinetic in order to print labels from the browser.
The underlying functionality works the same as in Classic, however in Kinetic we are getting error messages that reference the Edge Agent:
Everything works, all labels print, but we will occasionally (not always, which is weird) receive pop ups saying, âreport has been sent to Edge Agentâ and âError received from Edge Agentâ. The number of errors seems to coincide with the amount of different Report Styles that get exported. If you print Transit Tags, SOPs, and Material Tags, there will be three pop ups and three errors that have to be individually exited out of. If you print all of our labels (we have 5 different kinds), you will get 5 sets of pop ups and 5 individual errors.
We are confused when we see these errors, because it is our assumption that this does not utilize the Edge Agent. Our custom label program is built off of Data Directives that will export a file to an Azure File Share.
Our local on-premise Print Server with Bartender installed will poll specific folders inside of the Azure File Share to process and print labels to our network printers.
Epicor should not be directing this to âprintâ anything, only dropping files for our Bartender server to process. It is utilizing a Bartender Labels Report Type as a Report Style:
We reached out to EpicCare, they directed us to Professional Services since this is a completely custom program, which is understandable. However, we arenât really getting much from Professional Services either. They asked us to look into the Data Directives and verify that they are all set to print via the Bartender print style, and they all are. I have not received a response from them on where to go from here.
We want to roll out Kinetic to more people out on the floor, but most users print labels all throughout the day. I would hate to release this with constant errors and pop ups.
The only thing I can think of, is inside of the Data Directives. The Action does point to a Network Printer:
The way I thought it works is that when you choose a printer here, the logic behind the scenes will pull the Network Path from the associated Printer ID:
It will then use that Network Path to populate the drop file in the Azure File Share, directing Bartender what to print and to where:
However, it is still setup in there to âAuto Print to Network Printerâ, so I think that might be why the Edge Agent pop ups are coming from.
Well, tried changing every output icon to Auto Preview, didnât help. Not sure whatâs going on.
Any suggestions? Is it a configuration setting that we have setup, or is it something that could possibly be considered a bug, since it is setup to drop files (and does in Classic) without ever âprinting to a network printerâ?
