Kinetic Quick Search criteria (restore classic ui functionality)
We’re in the process of migrating custom work from E10 to Kinetic - the process is actually going somewhat better than I’d anticipated.
One item we’ve run into has to do with Quick Searches. We have a Parts by ClassID QS, which in E10 had a criteria to choose the ClassID. In E10 the criteria input was a combo listing all of the Classes, you could also type and select from the combo that way.
This is gone in Kinetic apparently? The closest I’ve seen is using a Value List but you have to manually add the values in QS Entry. We have many users who loved that functionality, is there a way to get it back in Kinetic?
Thanks in advance!
Hey Steve! Welcome to EpiUsers!
I poked around for quite a bit with this and was unable to find a clear solution to your issue.
You may be out of luck for now on this.
Epicor will probably tell you to submit an “idea” on their Ideas portal.
This has already been reported in PRB0247850.
PRB0247850 - Kinetic New UI Quick Search for Part_ClassID and Part_ProdCode not showing dropdowns.
Thank you so much for taking the time to look! I thought I was pretty clever in E10, Kinetic is quite the shift.
Many thanks for that information! This is precisely the 2 fields we’re having a problem with
