Kinetic REST API headaches
Well, today has been an interesting study in the API performance.
I ran multiple tests in three different configurations. This is my code executing, but the measurements are strictly from the API calls. Each test case was retrieved three times to get a sense of the general benchmark.
TestCases:
Case Name OrderDtls OrderRels JobProds/JobHeads Assemblies JobOpers JobMaterials
Case A 80 80 18 20 90 71
Case B 159 159 38 38 196 177
Case C 404 530 209 209 1377 1269
Test 1: Original SalesOrder and Job retrieval code using individual parallelized HttpCalls throttled to 16 simultaneous calls.
Case Run 1 (ms) Run 2 (ms) Run 3 (ms)
Case A 3322 3211 3465
Case B 5249 5680 5069
Case C 9004 8066 8053
Test 2: Refactored SalesOrder retrieval utilizing slimmed-down $select params in $expand statements. JobEntry code is still original retrieval.
Case A 1239 1137 1380
Case B 2566 2696 2455
Case C 6486 7038 6939
Test 3: Refactored SalesOrder and Job retrieval utilizing slimmed-down $select parameters in $expand statements.
Case A 863 901 883
Case B 2203 1715 1988
Case C 5033 4973 5273
As you can see, reducing the trips to the APIs has a profound effect on the performance. I suspect these retrievals can still be optimized further, which I will also explore after adding the Purchase Order data retrievals. Note that because of the nature of the SalesOrder/Job relationship, the code to retrieve jobs for an order still needs to utilize the JobProdSearchSvc to obtain a complete list of job numbers. Those can then be passed to the Erp.BO.JobEntrySvc API for hydration. Using $expand with pared-down $select parameters, I was able to eliminate similar gymnastics in the SalesOrder child retrievals, which is why I suspect the greatest performance improvement overall came between Test 1 and Test 2.
Yeah, like one trip with Kevin’s function.
No Chance Try It GIF by Tokyo Cowboys
Mine might not be any faster than a getbyid, I should have added more tests.
Yeah would love to know getbyid on these same 3 large cases. He was at 1800ms on the OrderSvc/getbyid before so there’s possibility slimming fields via $expand($select) is not better.
I don’t appear to have the authorization on our system to create functions - either that or I don’t know where I’m supposed to go in Epicor to create a new one.
Unfortunately, I don’t have time to whip it up, but my thought was:
Create three BAQs
Have a BAQ for orders (Head, Line, and Release), POs (Head, Line, Release), and Jobs (Head, Assembly, Material, Operations) where each returning relevant information for a particular sales order. The BAQs will take into account all security but also be the method to restricting fields. POs are tricky in that you can have a Drop Ship from a Sales Order or Buy Direct on a Job, so you’ll have to handle that.
Write a function that either:
  1. returns all three datasets or,
  2. if you want to retrieve the three sets in parallel asynchronously, then one function that returns a single selected dataset.
The time consuming work would be in shaping the datasets most usable by the client. Are you planning to assemble the pieces in the client or would you prefer to have it returned as one blob?
Ask your admin to authorize you in user account security.
In User Account Maintenance, make sure your ID is in these three groups:
And my data retrieval should be faster by bypassing the bo, but I added extra overhead by stripping out those two fields and some extra serialization.
Who knows lol.
Since you’re a DDD guy, @HornSounder, you’ll recognize the three BAQs would represent your aggregates.
FWIW, I’d say BAQs are kind of the sweet spot in the minimum customization approach for 3rd party integration. More than one big 3rd party integrator has simply passed a couple baqs for import and voila!
BAQs are compiled SQL queries, if I understand correctly, so perf should be good. You leverage server-side to control what you’re getting in the payload. More importantly, every company allows them, many users have the ability to import them, all without admin supervision (unlike functions).
That said, I’ve enjoyed highjacking this thread to learn about perf for all these options and hope you do try a function and finally compare all options to GetByID, if only for my selfish curiousity.
Not quite. It’s done every time.
SQL server will however learn the plan for better or worse lol.
True, but same for EF queries, no?
There is definitely a performance penalty in the added security code (company, site, territory, etc.) that each BAQ gets.
This has definitely been an educational interaction, yes.
The big win for me here has actually not been the performance, believe it or not. While that was the impetus for the thread and the performance increase is excellent, another significant benefit has been that two key classes are dramatically reduced in size and complexity. For those interested, here are the metrics for the two classes that make the calls:
Sales Order Service class: 179 LOC => 32 LOC
- Before Refactor: Cyclomatic Complexity 15, Maintainability 66, Class Coupling 25
- After Refactor: Cyclomatic Complexity 3, Maintainability 82, Class Coupling 10
Job Entry Service 171 => 111 LOC
- Before: Cyclomatic Complexity 18, Maintainability 58, Class Coupling 24
- After: Cyclomatic Complexity 13, Maintainability 64, Class Coupling 22
While the Job Entry service did not see as dramatic an improvement as the Sales Order service, all code metrics still benefitted from the refactor.
Indeed - I had that thought as I read your response.
After driving to and from Cleveland this weekend, I wondered: does your client REALLY need the whole shabang or can you use some lazy/on-demand loading? How is this data going to be consumed? Many GraphQL people (rightly) argue that we bring down too much data in REST. But in REST, we could download just the data we need by defining new resources. One could download the Order and the Lines with hyperlinks to releases first. The lines would have hyperlinks to the releases, and the releases have the hyperlinks to the POs and Jobs. I was thinking this is a great case to be more RESTful and use HATEOAS.
