Aaron,
I was able to sample the AMM last summer. Report quantity is a
function only in the AMM module. It allows employees to remain logged
into (start activity) a particular operation and report quantities.
When the employee is done for the day or has completed the opetaion
and 'Ends Activity' The data collection screen will display the total
quantity that has been entered since the activity was started. So
when entering a current quantity on the End Activity page. The total
quantity actually does something useful. Without AMM the total
quantity always equals the current quantity.
Jeff Larson can get you a 30 day trial. I strongly recommend it if
you have a backup server to test pilot the AMM module. Its a tough
module to startup
Pat Maher
module to startup
Pat Maher
--- In vantage@yahoogroups.com, "Aaron Hoyt" <hoyt@h...> wrote:
> Ron,
> Understanding that it is grey no mater what, it is possible it is
part
> of Advanced Material Management module.
> We do have that module, so what I can tell you is that it is grey
for me
> if I set the employee without the right to report quantity, and it
is
> enabled when I check the box giving them that right.
> Can anyone else confirm that the "report quantity" button in Shop
Floor
> is a function of AMM?
> Thanks,
> Aaron Hoyt
> -----Original Message-----
> From: Ron LaPean [mailto:rlapean@c...]
> Sent: Tuesday, March 09, 2004 9:32 AM
> To: 'vantage@yahoogroups.com'
> Subject: RE: [Vantage] LABOR REPORTING ISSUE
> Aaron:
> I understand where you got the information from the Help
Screen.
> Maybe I wasn't clear in explaining before.
> But.....
> 1. The Employee has all the Boxes Checked in the Employee
Master.
> 2. The Job has One Operation which is marked Qty Only. (I also
> tested
> with Time & Qty)
> 3. The Job is a Stocked Order. The Job is Engr and Released.
> 4. I then load the Shop Collection Module.
> 5. I sign into with the Employee who has all the boxes checked.
> 6. I located Job & highlight it.
> 7. When I highlight this job----the Report Quantity Button
remains
> Gray----it is not available
> 8. The only Buttons that are available from the Production
Tab -
> Work
> Queue, Count Entry, Non-Conformance and Kanban Receipt.
> 9. If I select the Sujpervisor Tab - all buttons are available.
> 10. I understand that I don't have some kind of advance
movement
> module
> that would allow me to use the Get Request, Return Request, and Move
> Request.
> 11. But----I would think I should have the Report Quantity.
> Aaron- From the Help and from your e-mails....it appears I
am
> doing
> the right things--yet the Report Quantity Button remains grayed out.
> Thanks
> for trying to help---not sure what it is---and without maintenance
from
> EPICOR I'm sure what to do.
> From: Aaron Hoyt [mailto:hoyt@h...]
> Sent: Tuesday, March 09, 2004 7:14 AM
> To: vantage@yahoogroups.com
> Ron,
> << What is this Production Browser Region? >> The area under the
> production tab in Shop Floor that shows what job you are working on.
> (Spreadsheet style, just above all the buttons.)
> << In using the Shop Data Entry Screen----When I highlight the Job
I am
> working on---the Quantity Reported Button still remains Gray and not
> available? >> Go into a full license. Production Management>Job
> Management>Master File Maintenance>Shop Employee. Choose the same
ID as
> the one you are using to log into Shop Floor. Check the box
allowing
> "Report Quantity". Log the employee out of Shop Floor and back
in. The
> button should now be available.
> I hope these are of some assistance in troubleshooting the issue.
> Good luck,
> Aaron Hoyt
> Hittite Microwave Corporation
> Sent: Monday, March 08, 2004 3:27 PM
> Aaron:
> As I indicated...we have 6.00.215. I added some notes
> below.
> Sent: Monday, March 08, 2004 10:12 AM
> Ron,
> First, thanks for dropping the All Caps. Not a big issue, but
> thanks.[Ron
> LaPean] Your welcome
> Second, from Vantage help:
> 1. In the Production browser region,[Ron LaPean] What is this
Production
> Browser Region? highlight the line corresponding to
> the job that you are working on.
> 2. Select Report Quantity. The Quantity Reporting window appears.
[Ron
> LaPean] In using the Shop Data Entry Screen----When I highlight
the Job
> I
> am working on---the Quantity Reported Button still remains Gray and
not
> available?
> Seems to indicate that it is only used to indicate to the next
operation
> that you have finished some material, but you are still working on
the
> rest.
> It also indicates that you can change the Job, Seq, Op, etc. but I
> believe this is designed to allow materials to flow from long
operations
> without completing the operation.
> Aaron Hoyt
> Sent: Monday, March 08, 2004 10:54 AM
> To: 'Vantage (E-mail)
> Subject: FW: [Vantage] LABOR REPORTING ISSUE
> does anyone have any suggestion or thoughts on the request below?
> thanks
> Ron
> Sent: Friday, March 05, 2004 3:38 PM
> Subject: [Vantage] LABOR REPORTING ISSUE
> I AM STILL IN THE TESTING MODE WITH VANTAGE 6.00.215.
> I HAVE ONE OPERATION ON THE ROUTING (SEQ 10) THAT CALLS FOR
LASER.
> I SET THE LABOR ENTRY = QTY ONLY.
> I HAVE THE BOXES CHECKED AUTO RECEIVE INTO INVENTORY; AND
FINAL
> OPERATION. THE FINISH TO START IS CHECKED ALSO.
> I HAVE 60 PCS/HOUR FOR THE STANDARD. MY MATERIAL = 50
LBS/PART.
> ON
> THE PART MASTER = INV/PURCH = I CHECKED THE BACKFLUSH.
> WHAT I WANTED TO DO WAS REPORT ONLY THE QUANTITY COMPLETED
VIA THE
> SHOP REPORTING DATA COLLECTION SCREEN.
> BUT WHEN I GO THERE----THE REPORT QUANTITY IS GRAYED OUT AND
NOT
> AVAILABLE. I CHECKED THE EMPLOYEE AND
> HE HAS ALL THE BOXES CHECKED--INCLUDING REPORT
QUANTITY. I
> WANT THE SYSTEM TO ALLOW ME TO
> REPORT QUANTITY---AND THEN IT AUTO MOVES THE QTY INTO
> INVENTORY AND BACKFLUSHES THE LABOR.
> THE JOB SHOULD BE UPDATED WITH THE LABOR AND THE
QUANTITY.
> DOES ANYONE HAVE ANY SUGGESTIONS?
> RON
> I CAN'T WAIT UNTIL I HAVE LIVE ACTIVITY UNDER MY
BELT.....
> "Paying the price" means choosing to lead and follow from
conviction,
> rather
> than reacting to circumstance.
> It means taking the time to mature, placing a higher value on
> character
> than on the short-term benefits of reaching a capacity goal.
> - The Ascent of a Leader
must
> have
Builder
> and
> <http://groups.yahoo.com/group/vantage/files/>
> <http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/> >
> <http://groups.yahoo.com/group/vantage/messages>
> <http://groups.yahoo.com/group/vantage/links>
> _____
> Yahoo! Groups Links
> * To visit your group on the web, go to:
> <http://groups.yahoo.com/group/vantage/>
> * To unsubscribe from this group, send an email to:
> vantage-unsubscribe@yahoogroups.com
> <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
> * Your use of Yahoo! Groups is subject to the Yahoo! Terms of
> Service
> <http://docs.yahoo.com/info/terms/> .
must
> have already linked your email address to a yahoo id to enable
access. )
Builder
> and Crystal Reports and other 'goodies', please goto:
> _____
> Yahoo! Groups Links
of
> <http://docs.yahoo.com/info/terms/> Service.
