Here is an old V8 example of an MES End Activity customization
- pops up different messages depending on previous qtys and new qty being reported
'// Custom VB.NET code for EndActForm
'// Rev01: 7/12/2010 - 8.03.04.409C
'// Custom Assembly References
'// Epicor.Mfg.AD.JobEntry
'// Epicor.Mfg.BO.JobEntry
'// Epicor.Mfg.IF.IJobEntry
'// Epicor.Mfg.AD.JobOperSearch
'// Epicor.Mfg.BO.JobOperSearch
'// Epicor.Mfg.IF.IJobOperSearch
'// Epicor.Mfg.AD.Labor
'// Epicor.Mfg.BO.Labor
'// Epicor.Mfg.IF.ILabor
Imports System
Imports System.Data
Imports System.Diagnostics
Imports System.Windows.Forms
Imports System.ComponentModel
Imports Microsoft.VisualBasic
Imports Epicor.Mfg.UI
Imports Epicor.Mfg.UI.FrameWork
Imports Epicor.Mfg.UI.ExtendedProps
Imports Epicor.Mfg.UI.FormFunctions
Imports Epicor.Mfg.UI.Customization
Imports Epicor.Mfg.UI.Adapters
Imports Epicor.Mfg.UI.Searches
Imports Epicor.Mfg.BO
Module Script
'// ** Wizard
Insert Location - Do Not Remove 'Begin/End Wizard Added Module Level Variables'
Comments! **
'// Begin
Wizard Added Module Level Variables **
'// End
'// Add
Custom Module Level Variables Here **
Sub InitializeCustomCode()
'// ** Wizard
Insert Location - Do not delete 'Begin/End Wizard Added Variable Intialization'
lines **
'// Begin
'// End
'// Begin
Custom Method Calls
'// End
Custom Method Calls
SetExtendedProperties()
End Sub
Sub DestroyCustomCode()
'// ** Wizard
Insert Location - Do not delete 'Begin/End Wizard Added Object Disposal' lines **
'// Begin
'// End
'// Begin
Custom Code Disposal
'// End
End Sub
Private Sub
Dim edvcJobOper As
EpiDataView = CType(oTrans.EpiDataViews("cJobOper"),EpiDataView)
If edvcJobOper.dataView.Table.Columns.Contains("RunQty")
Then
' Begin
Wizard Added ExtendedProperty Settings: edvcJobOper-RunQty
edvcJobOper.dataView.Table.Columns("RunQty").ExtendedProperties("Format")
= "->>>,>>>,>>>,>>9.99"
' End
End If
End Sub
Private Sub LaborDtl_BeforeFieldChange(ByVal sender As
object, ByVal args As DataColumnChangeEventArgs) Handles LaborDtl_Column.ColumnChanging
'// ** Argument
Properties and Uses **
'// args.Row("[FieldName]")
'// args.Column,
args.ProposedValue, args.Row
'Add Event
Handler Code
Select Case
args.Column.ColumnName
Case "LaborQty"
' Imports Epicor.Mfg.UI.Adapters
Dim joAdapt As
JobOperSearchAdapter = New JobOperSearchAdapter(EndActForm)
joAdapt.BOConnect()
Dim gotJo As
Boolean = false
try
gotJo = joAdapt.GetByID(args.Row("jobNum"),
args.Row("assemblySeq"), args.Row("oprSeq"))
catch e as
exception
'oTrans.PushStatusText("Did
not get Job " + args.Row("JobNum"),false)
end try
Dim
previousQuantityReported as decimal = 0
try
previousQuantityReported = GetPreviousQuantityReported(args.Row("JobNum"),args.Row("AssemblySeq"),args.Row("oprSeq"))
catch e as
exception
' oTrans.PushStatusText("Did
not get Previous Quantity for Job " + args.Row("JobNum") +
", " + e.message,false)
end try
Dim currentQuantityReported
as decimal = args.ProposedValue
Dim
totalQuantityReported as decimal = CDEC(previousQuantityReported) + CDEC(currentQuantityReported)
Dim
remainingQuantity as decimal = joAdapt.JobOperSearchData.Tables("JobOper").Rows(0)("RunQty")
- previousQuantityReported
if gotJo
try
Dim dRes
As DialogResult
if
totalQuantityReported > joAdapt.JobOperSearchData.Tables("JobOper").Rows(0)("RunQty")
MessageBox.Show("The current quantity entered of " + args.ProposedValue.ToString()
+ ", along with the previous quantity entered of " + previousQuantityReported.ToString()
+ ", gives a total quantity of " + totalQuantityReported.ToString() +
" which is greater than the " + joAdapt.JobOperSearchData.Tables("JobOper").Rows(0)("RunQty").ToString
+ " defined as the production quantity for this job assembly operation. Please try again", "Confirm Labor
Quantity")
args.Proposedvalue = 0
else
if args.ProposedValue
< joAdapt.JobOperSearchData.Tables("JobOper").Rows(0)("RunQty")
if
previousQuantityReported = 0
dRes = MessageBox.Show("The current quantity of " + args.ProposedValue.ToString()
+ " entered is less than the job assembly operation quantity of "+ joAdapt.JobOperSearchData.Tables("JobOper").Rows(0)("RunQty").ToString
+ ". To continue anyway, click Yes. Click No to correct your quantity.", "Confirm
Labor Quantity", MessageBoxButtons.YesNo)
else
if (args.ProposedValue
+ PreviousQuantityReported) < joAdapt.JobOperSearchData.Tables("JobOper").Rows(0)("RunQty")
Dim messageString as string = "The current quantity entered of "
+ args.ProposedValue.ToString() + ", along with the previous quantity
entered of " + previousQuantityReported.ToString() + ", gives a total
quantity of " + totalQuantityReported.ToString() + " which is less
+ " defined as the quantity for the job assembly operation. To continue anyway, click Yes. Click No to correct your quantity, and note
that a quantity of " + remainingQuantity.ToString()
+ " would complete this job."
dRes = MessageBox.Show(messageString, "Confirm Labor Quantity",
else
'Its
OK - they are reporting up to the valid job production quanity
dRes
= DialogResult.Yes
end if
end
if
If (dRes
= DialogResult.Yes) Then
'Continue
'args.Cancel
= True
Else
args.proposedValue = 0
End If
End if
End if
catch e
as exception
'oTrans.PushStatusText("Problem
checking quantities for " + args.Row("JobNum") + ", "
+ e.message,false)
end try
Else
not get Job Number " + args.Row("JobNum"),false)
End if
joAdapt.Dispose()
Case
Else
End Select
End Sub
Private Function
GetPreviousQuantityReported(jobNum as string, assemblySeq as integer, oprSeq as
integer) as decimal
Dim
previousQty as decimal = 0
DIm lbrDS as
System.Data.DataSet
Dim
whereClause as string = "JobNum = '" + jobNum + "' and
AssemblySeq = '" + assemblySeq.ToString() + "' and OprSeq = '" +
oprSeq.ToString() + "'"
Dim
recSelected as boolean = false
try
'try to
get labor transactions for job
lbrDS = SearchFunctions.listLookup(oTrans,"LaborDtlSearchAdapter",recSelected,false,whereClause)
if
recSelected
for
each lbrRow as DataRow in lbrDS.Tables(0).Rows
if
lbrRow("LaborQty") > 0
previousQty = previousQty + lbrRow("LaborQty")
end if
next
else
'messagebox.show
("No Labor Detail Records Found for whereClause " + whereClause)
end
if
catch e as
exception
'messagebox.show ("Problem getting
labor transactions for Job " + jobNum.ToString() + ", " + e.message
+ " using whereClause" + whereClause)
end try
return
previousQty
End Function
End Module
