Make a fields mandatory for particular Territory ID?
I’m trying to make some Customer Entry fields (both regular and UD) mandatory for a particular Territory ID.
I.e. Forcing the user to select a Customer Attribute.
I can force Industry Classes via Pre-Processing BPM via ds.CustIC, but I can’t get to ds.CustAttr because it doesn’t exist in the dataset.
Can this be done through Extended Properties or do I have to go via BPM?
If you need to build in logic where fields are only mandatory for a particular Territory ID, then you’re looking at a BPM.
For your Attributes issue, are you able to look at the Customer.AttrCodeList field in the BPM?
Also, in a BPM you can always get to fields that aren’t in the dataset by querying the db if you really need to. But hopefully you don’t have to in this case.
Thanks for this. Customer.AttrCodeList is exactly what I needed!
