Mandatory Field
Charlie's BPM is a good way to go. Epicor 9 adds a new applet called "Extended Properties" where you can declare a field mandatory and it becomes mandatory everywhere. There are some other features like restricting the value of a field to a selection list but I haven't got it to work consistently.
Mark W.
Happy Friday everyone!
Would someone direct me in the right direction in creating a mandatory
field please...
We have a new hire that is missing entries a lot and we would like to
make the
Quote Contact a required field, so that she has to input the contact
before she can save the record.
Thanks!
Ron Flynn
Cubic Designs, Inc.
CUSTOM MEZZANINE SYSTEMS
16770 West Victor Road
New Berlin, WI 53151
P: 262.789.1966
F: 262.789.1970
The easiest solution is to set up a BPM that checks each field for content
and then flies an error message when one isn't filled in.
Let me know if you need more detailed directions.
~Charlie
_____
IT Support
Sent: Friday, February 12, 2010 1:28 PM
Subject: [Vantage] Mandatory Field
field please...
make the
Thanks!
Ron Flynn
Cubic Designs, Inc.
P: 262.789.1966
F: 262.789.1970
Charlie,
Last day and all and your still helping out! Thanks!
I definitely need more direction, I was hoping it was simpler.
Thanks!
Of Charlie Wilson
Sent: Friday, February 12, 2010 12:32 PM
Subject: RE: [Vantage] Mandatory Field
content
~Charlie
_____
Behalf Of
IT Support
field please...
make the
Thanks!
Ron Flynn
Cubic Designs, Inc.
P: 262.789.1966
F: 262.789.1970
The BPM would actually be very easy to setup.
You will want to go to your method directives load in the directive that you
need to focus on. Lets say we are going to check for the Burden Field on the
part master.
You would want to load Part.Update.
You will then select that you want a new "Pre-processing" bpm.
Give it a name and either set it to a group or not (the group is up to you)
Your condition is going to be "the specified field of the changed row is
equal to value"
You are then going to click "specified" Select TTpart from the drop down
and then locate the MTLBurRate field click okay.
Then select value and check the null check box.
Now for the action you want to select "raise exception based on designed
template"
Select designed and then fill that form in.
You will then need to set the BPM to compatible if it is not and enable it.
This will stop the user from moving forward with out first putting at least
something in the burden rate field. To be honest this field may already be
mandatory I'm not sure but it was just an easy example cuz I was already
working on that field.
Now if you had a whole list of fields you want to check you have an choice
to make. You can create 1 BPM with multiple " the specified field of the
changed row is equal to value" with ands in between each and one general
exception message or you could have a bpm for each field and have an error
message for each field so that the user knows exactly what field(s) they
missed.
Or........... you could just charge them 10 dollars each time they miss a
field and forget the whole BPM idea..
~Charlie
_____
IT Support
Sent: Friday, February 12, 2010 1:39 PM
Charlie,
Thanks!
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Charlie Wilson
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
content
~Charlie
_____
Behalf Of
IT Support
field please...
make the
Thanks!
Ron Flynn
Cubic Designs, Inc.
P: 262.789.1966
F: 262.789.1970
Charlie,
Thank you!
& Best wishes with the job change,
Ron Flynn
Cubic Designs, Inc.
P: 262.789.1966
F: 262.789.1970
Of Charlie Wilson
Sent: Friday, February 12, 2010 1:57 PM
you
the
part master.
you)
equal to value"
template"
it.
least
be
choice
error
missed.
a
~Charlie
_____
Behalf Of
IT Support
Charlie,
Thanks!
Behalf
Of Charlie Wilson
content
~Charlie
_____
Behalf Of
IT Support
field please...
make the
Thanks!
Ron Flynn
Cubic Designs, Inc.
P: 262.789.1966
F: 262.789.1970
