Vic,
In our version of Vista 8.03.405B, when using this setup for a
required field, I receive the following message:
Warning - Mandatory Row rules are an unsupported feature that may not
behave uniformly across all business objects in the application. If
you wish to continue to use this feature please test to ensure
expected behavior for the instance that you are developing. The
preferred technique for ensuring mandatory fields is to use a BPM
directive to test condition for empty string and raise appropriate
exception action.
I am able to setup mandatory fields as a BPM that works.
I found an example in the "Business Process Management Student Manual"
Dave
exception action.
Dave
--- In vantage@yahoogroups.com, "Vic Drecchio" <vic.drecchio@...> wrote:
> Easy, it's all documented in version 8.x Help. Hit F1 and search for
> "How do I set up a required field?"
> Or, here's the contents:
> Purpose
> You can indicate that a field is required, or mandatory, by using the
> Rule Wizard
> <file://SEAHAWK/epicor/mfgsys803/Help/enu/Vantage/User_Preferences/Custo
> mWizardRule.htm> . You do this by first creating a mandatory rule and
> then adding a mandatory rule action to it. Here's how:
> 1. Within the Customization Tools Dialog, click on the Wizards tab
> and the Rule Wizard tab.
> 2. Click the New Row Rule button.
> 3. For the Rule Description field, enter a description that
> indicates this is a mandatory row rule. For example: MyMandatoryRule
> 4. Now on the Select View list, choose the table, or dataView, that
> contains the field you want to make mandatory. For example: ShipVia
> 5. Set up the rule condition so the Select Field is always equal to
> itself. To do this, select the same option for the Select Field and Rule
> Value lists and then select Equals for the rule condition.
> Example: You want the Web Description field to be mandatory on the Ship
> Via Maintenance form. Because this is a character field, you choose
> these options in the following fields:
> -Select Field: Character01
> -Rule Condition: Equals
> -Rule Value: Character01
> This makes the field mandatory, as the rule condition
> Character01=Character01 will always evaluate to true.
> 6. Click the Right Arrow button to add the rule to the Custom Row
> Rules list.
> 7. Now click the New Rule Action button.
> 8. In the Select Field list, choose the field that you want to be
> mandatory. For example: WebDesc
> 9. Next, in the Setting Styles list, select the Mandatory option.
> 10. Click the Right Arrow button to add this file to the Custom Rule
> Actions list.
> 11. Click the Update button.
> Now when users try to save a record and the selected field is blank, an
> Application Error message will appear. In the example below, the user
> tried to save a Ship Via record without entering a Web Description.
> Vic Drecchio
> ERP Administrator
> TIMCO Aviation Services
> Greensboro, NC
> Email: vic.drecchio@...
> Office: 336.668.4410 x3091
> Mobile: 704.530.3092
> Of Dale R. Kalsow
> Sent: Monday, July 07, 2008 8:34 AM
> To: vantage@yahoogroups.com
> Subject: RE: [Vantage] Re: PO BMP
> I probably missed it but how do you make a field required?
> Thanks!
> Dale
> [mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Behalf
> Of Calvin Krusen
> Sent: Thursday, July 03, 2008 2:58 PM
> Subject: [Vantage] Re: PO BMP
> Scott -
> How do you make a field mandatory in the customization environment?
> Maybe my problem is that I want to make the Product Group Code
> manditory, but the UI implemts it as a dropdown box that displays the
> underlying ProdCode's Description.
> Thanks,
> Calvin
> --- In vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com>
> <mailto:vantage%40yahoogroups.com> ,
> "Scott Litzau" <scott.litzau@>
> wrote:
> > Go into customization and make it a mandatory field.
> > Scott Litzau, MCP
> > Olympus Flag & Banner
> > Information Systems Manager
> > scott.litzau@
> > P: 414-365-9732
> > F: 414-355-1931
> > -----Original Message-----
> Behalf Of
> > Dale R. Kalsow
> > Sent: Thursday, July 03, 2008 1:18 PM
> > Subject: [Vantage] PO BMP
> > Does anyone have a BPM that forces the user to enter an account #
> in PO
> > entry? Or some other way to do this?
> > Thanks!
> > Dale
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have
> > already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> <http://groups.yahoo.com/group/vantage/files/.>
> <http://groups.yahoo.com/group/vantage/files/> >
> > http://groups.yahoo.com/group/vantage/messages
> <http://groups.yahoo.com/group/vantage/messages>
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo
> <http://groups.yahoo.com/group/vantage/linksYahoo> ! Groups Links
