We have 3.0 and do not have the ABOM, but I believe we solved the
problem you are having in what we call our Job Structure Report which
shows all assemblies, operations and materials (linked to the
operation), for any job, one at a time. Using a quantity of one, we use
the report to verify our job structure, quantity per parent, etc. This
way we can look at the entire job instead of just a piece of it on the
vantage job entry screen. We also have two simple job material summary
reports, one is by the assembly and the other is by material part
number, both total the material requirements.
I will ask our report writer to upload these three reports along with
our Shortage Report this Friday.
Steve
Ps Sorry about the delay in uploading our shortage report as I have
been out since last Wednesday and our report writer will not be in until
Friday.
[SMTP:abelagardi@...]
Sent: Friday, September 29, 2000 12:57 PM
To: vantage@egroups.com
Subject: [Vantage] Master Methods Listing/Report Builder
Has anyone tried to re-build the Master Methods Listing using
Report
Builder? I am in the process of doing that. I'm almost done but
I
have a little problem when we use more than one part material to
build the final product. In other words, if our final product is
made
of one single part material, my report works pretty good. I get
the
part material specifications and then all the operations
sequences
the part needs to go through. But, when the final product
requires
more than one material, let's say 10 different parts, I cannot
get
those 10 different parts list together at the beginning of my
report.
Instead, I get an endless report of 10 times each operation
sequence
under each material part.
If someone tried to do this before:
1. Can I get your version of the report so I can add the the
extra
info we need in it? Or ...
2. Can you give me a hint on why this is happening and how to
try to
solve it?
Thank you in advance! Angela.
-------------------------- eGroups Sponsor
We no longer allow attachments to files. To access/share Report
Files, please go to the following link:
http://www.egroups.com/files/vantage/
(Note: If this link does not work for you the first time you
try it, go to www.egroups.com, login and be sure to save your password,
choose My Groups, choose Vantage, then choose Files. If you save the
password, the link above will work the next time you try it.)
Steve
Friday.
Report
I
made
the
sequences
requires
get
report.
sequence
extra
try to
solve it?
