We have different colors for each plant for our Vantage Plant Floor. To
set this up we logged into each code through Vantage (full version).
Set the colors for the text/background. Then removed the ability for
these logins to change the colors. Set two separate Vantage Plant Floor
icons up: PLANT1 and PLANT2. Each plant icons automatically logs on
with the appropriate sign on. Now when someone walks up to a terminal
that has both plants open they can tell right away what plant they are
in.
Juliet
Vantage 5.1
Sent: Thursday, August 15, 2002 3:57 PM
Subject: Re: [Vantage] Menu color change
You know this is similar to what we were doing when we first installed
Vantage 3 and running tests.
We had our primary database and our test database with desktop links to
both.
We went to every work station and the changed the Vantage screen colors
for the test database so all employees would know the difference between
the test and the actual databases.
I seems as though you could do something similar.
One database and color scheme for presale and one for after sale.
Rich
in.
Juliet
Vantage 5.1
both.
Rich
----- Original Message -----
Sent: Thursday, August 15, 2002 1:55 PM
Subject: RE: [Vantage] Menu color change
We are on version 5:00 3:50. Our company has recently sold off part
of the company and we would like to setup a new company for the part
that remains. In setting up a new company I would like to change the
color of the menu items so as to distinguish which company is which
so that people entering data will know there in the new company. I
know I can change the color of the data entry items but can you also
change the top menu item color? Also on the favorites bar, you can
change the background color, but that color will now be the same for
both companies. Does anyone know how you can change the background
color and have it be different for each company? As always your help
is appreciated.
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
