We also have the security button unchecked in the ODBC configuration, but
get the Progress login the first time you open a report, but not thereafter.
In Crystal 8, using the Web Server component (which will take a bit of
simple HTML coding), you can set up each report in a web page -- and the
user simply clicks on one of the links. You can have the password and
username embedded in the link so they don't need to enter it manually. That
might work if you use Crystal 8's Web Server Component. I've just been
experimenting with it as an alternative to compiling reports.
Troy Funte
Liberty Electronics
Troy Funte
Liberty Electronics
----- Original Message -----
To: <vantage@egroups.com>
Sent: Tuesday, October 03, 2000 5:47 PM
Subject: [Vantage] Merant ODBC and Crystal Reports
> Hopefully a simple question. Is there a way to bypass the Progress login
> when I fire up a Crystal report that attaches directly to the Vantage
> tables? We have the company's founder (84 years old and still very much
> going) who wants a SIMPLE way to run reports from his PC (yes he does use
> one). He does not log into Vantage (too much screen activity to log on)
so
> I have contemplated using a Crystal compiled report to run from a shortcut
> on his screen. Now I have the problem of getting past the Progress login
> screen (there is no Progress password on my
> Vantage database).
> Any Ideas?
> H. Dale Puls
> Pacesetter Electronics
> We no longer allow attachments to files. To access/share Report Files,
> (Note: If this link does not work for you the first time you try it, go
to www.egroups.com, login and be sure to save your password, choose My
Groups, choose Vantage, then choose Files. If you save the password, the
link above will work the next time you try it.)
