I did some searching and found that this is being used as a substitute
for the Progress Explorer. I haven't used it yet myself since I am still
on 8.03 but I will be converting in the near future
http://www.squirrelsql.org/#installation
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
The Standard in Optical Filters for Biotech & Analytical Instrumentation
Hundreds of Thousands of Ion Beam Sputtered filters delivered -
extensive inventory now!
The information contained in this message and any attachments may be
privileged, confidential, and protected from disclosure. If the reader
of this message is not the intended recipient, or any agent responsible
for delivering this message to the intended recipient, you are hereby
notified that any dissemination, distribution, or copying of this
communication may be unlawful and therefore strictly prohibited. If you
received this message in error, please reply to the message and delete
it. Thank you
Of charles06072006
Sent: Wednesday, January 23, 2008 5:44 PM
Subject: [Vantage] Re: Crystal Reports in Vantage 8.03
I have not found a way to do it in 10.1b. I used progress explorer
on 10.0b but that has gone away with 10.1b. I you find a way please
let me know as I will soon be upgrading to 10.1b with the 8.03.400
move.
"Matt Caldwell" <matt@...> wrote:
Behalf
Fons
Kersten MacLennan
IT/ERP Analyst
Semrock, Inc.
3625 Buffalo Rd.,
Suite 6
Rochester, NY 14624
585-594-7009
585-594-7095 fax
kmaclennan@...
it. Thank you
Of charles06072006
move.
>[mailto:vantage@yahoogroups.com <mailto:vantage%40yahoogroups.com> ] On
> Would any of you happen to have a "How-To" on setting up a progress
> user? We are using Progress 10.1B.
> --Matt
Behalf
> Of saab_barracuda<mailto:vantage%40yahoogroups.com> ,
> Sent: Wednesday, January 23, 2008 3:16 PM
> Agreed. Hopefully everyone is using "odbcuser" setup with limited
> table access (as recommended in the ODBC Toolkit).
Fons
> van der BeekWRITE
> <fons.vanderbeek@> wrote:
> > It is wise NOT to use sysprogress as user, because this user has
>using
> > access in the database....................
> > saab_barracuda schreef:
> > > Here you go...
> > > Summary: CR Bypass the login ID and prompt for a Crystal Report
> using
> > > an ODBC connection.
> > > Book: Support Solutions
> > > Page: 5947MPS
> > > PROBLEM: Bypass the login ID and prompt for a Crystal Report
> anusing
> > > ODBC connection.
> > > A Crystal form that has been modified with a subreport written
> > > an ODBC connection continues to prompt for the ODBC System DSNlogin
> > > ID and password parameters.client
> > > The ODBC Driver for Open Edge 10.0B must be installed on each
> > > that will be using an ODBC modified report. See document4778MPS for
> > > instructions on modifying a Crystal Report to use ODBC.Crystal
> > > For V8.03, an ODBC driver is not necessary for a customer
> > > Report. See document 7931MPS for instructions on creating aCrystal
> > > Report from a BAQ within V8.03.and
> > > RESOLUTION:
> > > 1. Go to Start->Run, and type in REGEDIT.
> > > 2. This will bring up your Registry Editor.
> > > 3. Find the HKEY_LOCAL_MACHINE\SOFTWARE\ODBC\ODBC.INI.
> > > 4. Find your specific ODBC connection that is setup in your ODBC
> > > datasources and double-click on it.
> > > 5. Go up to the Edit -> New -> String Value in the menu.
> > > 6. Give your New String Value the name of User ID.
> > > 7. Then double-click and give it a value of sysprogress. (Or
> whatever
> > > your user id is setup to be.) 8. Repeat the process for your
> Password.
> > > 9. Exit the Registry.
> > > 10. In the SystemTaskAgent (System Management->Utilities->System
> > > Agent), under ODBC Connection, put in the User ID and Password
> above.
> > > 11. In the Progress Explorer Too, stop and start the TaskAgent
> > > ProcessServer for this database.<mailto:vantage%
> > > 12. Test your report and you should not get prompted.
> "randyduly" <randy.duly@> wrote:(the
> > >> I have created Crystal Reports for Vantage 8.03 and have added
> them to
> > >> the Custom Report Menus in Vantage. The problem I have if I
> > >> administrator run the report, they run without prompting for ause
> username
> > >> and password. But if the user run the Crystal Report from the
> Custom
> > >> Report menu, they are prompted for a username and password to
> connect
> > >> to the Vantage Database, even if the check box is checked for
> the<http://groups.yahoo.com/group/vantage/files/.>
> > >> default username and password.
> > >> Has anybody else had this problem?
> > >> Thanks in advance.
> > >> Randy Duly
> > >> National Tube Form
> > >> randy.duly@
> > > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
> must have already linked your email address to a yahoo id to enable
> access. )
> > > (1) To access the Files Section of our Yahoo!Group for Report
> Builder and Crystal Reports and other 'goodies', please goto:
> <http://groups.yahoo.com/group/vantage/files/<http://groups.yahoo.com/group/vantage/files/> >
> > > (2) To search through old msg's goto:<http://groups.yahoo.com/group/vantage/messages>
> > > (3) To view links to Vendors that provide Vantage services goto:<http://groups.yahoo.com/group/vantage/links>
> > > Yahoo! Groups Links[Non-text portions of this message have been removed]
