LynnDavid
(Lynn David)
October 15, 2019, 4:21pm
1
I have a Method Directive enabled on CreateOrder for Quotes that is creating new parts when a certain radio button is marked to “Yes”. It is a Post Process and there are 3 execute custom code. 1st one creates Part record, 2nd one created PartPlant record and 3rd one creates PartWhse. The issue is the PartWhse is running before the PartPlant record and cannot get it to go last.
Any suggestions would be great. I was trying to use callContextBpmData to try and have it go in order but not working.
It’s likely you don’t have the sequence set correctly. They run in numerical order.
LynnDavid
(Lynn David)
October 15, 2019, 5:22pm
3
They are all inside one Directive. It does not follow if separate even using the Order No for the directive to start at different times.
I suppose it depends on what the code is doing inside.
LynnDavid
(Lynn David)
October 15, 2019, 5:49pm
5
Part Create code:
Erp.Tables.QuoteDtl QuoteDtl;
foreach (var QuoteDtl_iterator in (from QuoteDtl_Row in Db.QuoteDtl
where QuoteDtl_Row.Company == Session.CompanyID
&& QuoteDtl_Row.QuoteNum == callContextBpmData.Number06
&& QuoteDtl_Row.NewPart_c == “Yes”
select QuoteDtl_Row))
var QuoteDtlRow = QuoteDtl_iterator;
if (QuoteDtlRow != null)
Part newpart = new Part();
Db.Part.Insert(newpart);
newpart.Company = Session.CompanyID;
newpart.PartNum = QuoteDtlRow.PartNum;
newpart.PartDescription = QuoteDtlRow.LineDesc;
newpart.TypeCode = QuoteDtlRow.TypeCode_c;
newpart.ProdCode = QuoteDtlRow.ProdCode;
newpart.RefCategory = QuoteDtlRow.RefCat_c;
newpart.Print_c = QuoteDtlRow.Print_c;
newpart.Material_c = QuoteDtlRow.Material_c;
newpart.Diameter_c = QuoteDtlRow.Diameter_c;
newpart.Lth_c = QuoteDtlRow.Lth_c;
newpart.Wdth_c = QuoteDtlRow.Wdth_c;
newpart.CenterThick_c = QuoteDtlRow.CenterThick_c;
newpart.Thickness_c = QuoteDtlRow.Thickness_c;
newpart.EdgeThick_c = QuoteDtlRow.EdgeThick_c;
newpart.CSM_c = QuoteDtlRow.CSM_c;
newpart.Chips_c = QuoteDtlRow.Chips_c;
newpart.Edges_c = QuoteDtlRow.Edges_c;
newpart.Chamfers_c = QuoteDtlRow.Chamfers_c;
newpart.Coating_c = QuoteDtlRow.Coating_c;
newpart.Centration_c = QuoteDtlRow.Centration_c;
newpart.Wedge_c = QuoteDtlRow.Wedge_c;
newpart.TIR_c = QuoteDtlRow.TIR_c;
newpart.TrnWve_c = QuoteDtlRow.TrnWve_c;
newpart.Parallel_c = QuoteDtlRow.Parallel_c;
newpart.DocReq_c = QuoteDtlRow.DocReq_c;
newpart.PackReq_c = QuoteDtlRow.PackReq_c;
newpart.MatCerts_c = QuoteDtlRow.MatCerts_c;
newpart.SurfaceQual_c = QuoteDtlRow.SurfaceQual_c;
newpart.SurfaceAcc_c = QuoteDtlRow.SurfaceAcc_c;
newpart.SurfaceRough_c = QuoteDtlRow.SurfaceRough_c;
newpart.ClearApert_c = QuoteDtlRow.ClearApert_c;
newpart.Radius_c = QuoteDtlRow.Radius_c;
newpart.Spec1R2_c = QuoteDtlRow.Spec1R2_c;
newpart.SurfQual2_c = QuoteDtlRow.SurfQual2_c;
newpart.SurfAcc2_c = QuoteDtlRow.SurfAcc2_c;
newpart.SurfRough2_c = QuoteDtlRow.SurfRough2_c;
newpart.ClearApert2_c = QuoteDtlRow.ClearApert2_c;
newpart.Spec2R1_c = QuoteDtlRow.Spec2R1_c;
newpart.Spec2R2_c = QuoteDtlRow.Spec2R2_c;
newpart.CS1_c = QuoteDtlRow.CS1_c;
newpart.CS2_c = QuoteDtlRow.CS2_c;
newpart.CS3_c = QuoteDtlRow.CS3_c;
callContextBpmData.Number07 = QuoteDtlRow.QuoteNum;
this.PublishInfoMessage("QuoteDtl.PartNum: " + QuoteDtlRow.PartNum + " " + " QuoteDtl.QuoteNum: " + QuoteDtlRow.QuoteNum + " newpart.PartNum: " + newpart.PartNum , Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "QuoteDtl-Post1", "CreateOrder");
LynnDavid
(Lynn David)
October 15, 2019, 5:50pm
6
PartPlant Create code:
using (var txScope = IceContext.CreateDefaultTransactionScope())
&& QuoteDtl_Row.QuoteNum == callContextBpmData.Number07
PartPlant newpartplant = new PartPlant();
Db.PartPlant.Insert(newpartplant);
newpartplant.Company = Session.CompanyID;
newpartplant.Plant = "MfgSys";
newpartplant.PartNum = QuoteDtlRow.PartNum;
newpartplant.PrimWhse = "Main";
newpartplant.SourceType = QuoteDtlRow.TypeCode_c;
callContextBpmData.Character10 = newpartplant.PartNum;
//callContextBpmData.Number07 = QuoteDtlRow.QuoteNum;
this.PublishInfoMessage("QuoteDtl.QuoteNum: " + QuoteDtlRow.QuoteNum.ToString() + " QuoteDtl.PartNum: " + QuoteDtlRow.PartNum + " newpartplant.Part: " + newpartplant.PartNum + " newpartplant.Plant: " + newpartplant.Plant + " BPMData.C10: " + callContextBpmData.Character10, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "Quote-Post2", "CreateOrder-Post");
Db.Validate();
txScope.Complete();
LynnDavid
(Lynn David)
October 15, 2019, 5:51pm
7
PartWhse Create Code:
using (var txScope = IceDataContext.CreateDefaultTransactionScope())
var PartWhse = from pw in Db.PartWhse.With(LockHint.UpdLock)
where pw.Company == Session.CompanyID
&& pw.PartNum == callContextBpmData.Character10
select pw;
this.PublishInfoMessage("CCBpmData.C10: " + callContextBpmData.Character10, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "QuoteDtl-Post2", "CreateOrder");
if (PartWhse != null)
PartWhse newpartwhse = new PartWhse();
Db.PartWhse.Insert(newpartwhse);
newpartwhse.Company = Session.CompanyID;
newpartwhse.PartNum = callContextBpmData.Character10;
newpartwhse.WarehouseCode = "Main";
this.PublishInfoMessage("newpartwhse.PartNum: " + newpartwhse.PartNum + " newpartwhse.WarehouseCode: " + newpartwhse.WarehouseCode, Ice.Common.BusinessObjectMessageType.Information, Ice.Bpm.InfoMessageDisplayMode.Individual, "QuoteDtl-Post3", "CreateOrder");
Db.Validate();
txScope.Complete();
LynnDavid
(Lynn David)
8
I attached the code for all 3 custom code.
Thanks. I would offer that you should use the Business Object Method instead of the “Insert”.
LynnDavid
(Lynn David)
October 15, 2019, 5:59pm
10
i tried adding Erp.Contract.BO.Part to directive, but i get the following error:
There is at least one compilation error.
CreateOrder.CommonTypes.cs(346,33): error CS0433: The type ‘PartSubsTable’ exists in both ‘Erp.Contracts.BO.Part, Version=10.2.300.0, Culture=neutral, PublicKeyToken=5d3fa3c7105d7992’ and ‘Erp.Contracts.BO.Quote, Version=10.2.300.0, Culture=neutral, PublicKeyToken=5d3fa3c7105d7992’
I wish there was a more viable solution for these. Can you use a CallContext and a Data Directive with Code and a BO?
LynnDavid
(Lynn David)
October 15, 2019, 6:12pm
12
Unfortunately if I set a CallContext in Method Directive, the Data Directive does not see it or find it.
Really?!? That’s a surprise. I guess I don’t recall if I’ve used that before.
Can you use a Data Directive on OrderDtl when a new record is added with a QuoteNum?
LynnDavid
(Lynn David)
October 15, 2019, 6:17pm
14
i just tried it again and the QuoteDtl Standard Directive did pick up on the CallContext.
Perfect. That should work then.
LynnDavid
(Lynn David)
October 15, 2019, 6:18pm
16
But the Standard Directive did not start when call the Create Order. Only when changed Quote Detail.
LynnDavid
(Lynn David)
October 15, 2019, 6:23pm
17
nope. I need the Data Directive called or started when CreateOrder is launched.
LynnDavid
(Lynn David)
October 15, 2019, 6:25pm
18
The orderdtl Standard Directive found the callContext record and I was able to add the Erp.Contracts.BO.Part to the References section. But the standard does not have the option for “Invoke BO Method”.
jgiese.wci
(Joshua Giese)
October 15, 2019, 6:27pm
19
LynnDavid
(Lynn David)
October 15, 2019, 6:32pm
20
When I add that code in I get an error: "The type or namespace name ‘Internal’ does not exist in the namespace ‘Erp’ (Are you missing an assembly reference?)
