Minor search change on AR Invoice Tracker
We are doing upgrade testing to 2024.1 and someone noticed a change in the behavior of the search.
In 2023.1.9 you can just put in a number, and the search defaults to invoice number, even if you don’t select anything in sort by field.
Now, if you don’t pick something, it’s trying to pass in a string with leading spaces. If you pick invoice number, it works fine (so it’s a small nit picky thing). However we anticipate users complaining about it.
Does anyone else see this? Obviously only in classic forms/search.
I see it too @Banderson :smiling_imp:
I opened a ticket, I had @hkeric.wci check on their system same issue. @klincecum you are in 2024.latest you got that same issue?
INVOICENUM <= ' 5'
Somebody be adding single quotes to my numerals methinks.
PRB: PRB0285783 ← Don’t click it , it don’t work @klincecum (but it works for me)
Record not found
works on my machine.
I didn’t mean to make it a link :joy:
I guess it’s not fully accepted yet, doesn’t show in the problem repository either.
Or that may update on a schedule.
Unrelated, except that is ARInvoice.
Version 23.2 (i think).
Executing GetShipments from Classic and Kinetic calls 2 different methods.
Classic: ARInvoice.GetShipments
Kinetic: ARInvoice.GetShipmentsConsolidatedPS
I spent too much time pulling hair before I noticed this.
There was a LOT of changes similar to this @Chris_Conn I would say almost every other Kinetic screen now calls a “special/new” BO
Seriously, I’m almost always tracing in the browser now unless it HAS to work in classic.
I do too much development to spend my time hoping a Kinetic screen will either work as intended, or even be made yet for my purposes.
Short of having both types open at once to get stuff done, classic is still 10x more reliable than kinetic, baring silly (unexpected, unannounced) changes like these.
It’s not who moved my cheese, it’s who replaced it with a cheese like substance.
Are you saying that Kinetic UX is Kraft Singles
It (the browser) goes on everything!
You mean the Microsoft wEdge browser? :cheese:
OMG that is so dang aggressive. It REALLY wants to be my default PDF viewer and I can’t understand WHY!!! Any time I download a PDF it makes itself the default PDF viewer, and I cannot figure out how to stop if from doing that!
I DON’T WANT YOUR CHEEZE WHIZZ M$!
Yep, we’re going to have to rewrite a bunch of BPMs because of this. I might even have 2 sets of BPMs going for the couple years or so that we expect to be half classic half browser…
