Wow. I am checking version 5, and it has the same glitch.
Sent: Thursday, April 05, 2001 2:54 PM
Subject: RE: [Vantage] Modifying the right click menu contents
Paul,
The only way to change the "Open With" functionality is by modifying the
source code.
In this particular case, I believe that there is a bug in the software (at
least in version 4.0.811).
When you select a vendor and the list of open orders shows up in the bottom
browser, the "Open With" routine looks at the fields in the browser and
since it finds the column header "Order" it causes the "Open With" menu to
pop up. Next it looks at the value in the Order column. If that's a valid
order number its supposed to allow you to select PO tracker. For some odd
reason in this case it doesn't.
You might want to report it to Epicor as a bug. I'm sure they'll put it at
the top of their priority list. :-)
Steve Sanders
Delta Centrifugal Corp.
Sent: Thursday, April 05, 2001 1:23 PM
Subject: [Vantage] Modifying the right click menu contents
Next question;
Is there a way to modify the contents of the right click menu ("open with"
function)? When I am in the Purchase Order Entry window and I do a search
by
Vendor Name Or Vendor ID (and only by either one of those) I would like to
include the option to open a line with the PO Tracker. Right now this is
not a choice...
Thanks for any info...
Paul Siebers
Yahoo! Groups Sponsor
Click Here to Find Software Faster
To access the Files Section of our Yahoo!Group for Report Builder and
Crystal Reports and other 'goodies', please go to:
<http://groups.yahoo.com/group/vantage/files/.> Note: You must have
already
linked your email address to a yahoo id to enable access.
<http://rd.yahoo.com/M=162801.1342250.2934640.1280005/D=egroupmail/S=1700007
183:N/A=599088/*http://www.knowledgestorm.com/jump_white.html?c=Yahoo&n=eLer
t_ComputersInternet_Software_WhiteGridTime&t=ad> Click Here to Find Software
Faster
<http://us.adserver.yahoo.com/l?M=162801.1342250.2934640.1280005/D=egroupmai
l/S=1700007183:N/A=599088/rand=735365996>
already linked your email address to a yahoo id to enable access.
<http://docs.yahoo.com/info/terms/> Service.
Paul,
source code.
Steve Sanders
Next question;
by
not a choice...
Paul Siebers
already
Faster
