Version 905.607B - Help with Right-Click Menu Item - Open With
Thanks Ted, that did it!
Thanks to all, I think you were all trying to get me there I was just brain dead!
Ray
--- In vantage@yahoogroups.com, "zanniebelle" <rwatson@...> wrote:
> Thanks Ted, I'll give it a try.
> --- In vantage@yahoogroups.com, Ted Koch <tkoch77@> wrote:
> > Go to epicweb and search for answerbook 10990ESC... follow the steps for modifying a subprocess.
> > Hope that helps,
> > Ted
> > ________________________________
> > From: zanniebelle <rwatson@>
> > Sent: Monday, June 25, 2012 12:51 PM
> > Subject: [Vantage] Re: Version 905.607B - Help with Right-Click Menu Item - Open With...
> > Hi Brian,
> > The form "App.CustomerEntry.ShipToEntryForm" is only available through the CustomerEntry BO. I can customize it, but I can only select a "CustomerEntry" customization when creating the menu item. There's no way to tell CustomerEntry to use the customization for the ShipToEntryForm.
> > To reproduce the issue (in developer mode):
> > 1. Open Order Entry and select an existing order where the shipto Id is populated.
> > 2. Right-Click the field and select "Open
> > > With...->Customer Ship To Entry"
> > 3. Note App.CustomerEntry.ShipToEntryForm opens.
> > 4. Customize the form and save it.
> > I have foud no way to open that form using the new customization.
> > Thanks for the reply.
> > Ray
> > --- In vantage@yahoogroups.com, "Brian Roberts" <broberts@> wrote:
> > > First, add it as a menu item under processes, with a program of
> > > Epicor.Mfg.UI.CustomerEntry.dll, and select your customization there.
> > > Then, add the link in Process Calling Maintenance (sys mgmt. ->
> > > utilities menu). Called process is Epicor.Mfg.UI.CustomerEntry, Called
> > > From is Epicor.Mfg.UI.SalesOrderEntry, and the menu item is the one you
> > > just created with your customization.
> > >Â
> > > Brian.
> > >Â
> > > From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf
> > > Of zanniebelle
> > > Sent: Monday, June 25, 2012 9:23 AM
> > > Subject: [Vantage] Version 905.607B - Help with Right-Click Menu Item -
> > > Open With...
> > >Â
> > >Â
> > > Hi All,
> > > We have an extensive customization to the Customer Entry Form, including
> > > the Ship To details tab. It is located under Sales Management->Order
> > > Management->Setup, with menu Id OMMT1110.
> > > In Order Entry, on the Ship To field there is a Right-Click "Open
> > > With...->Customer Ship To Entry" menu item, which when traced it looks
> > > like it calls the menu item above, OMMT1110.
> > > The problem is it loads a Ship To Maintenance Form
> > > (App.CustomerEntry.ShipToEntryForm) not the Customer Entry form we
> > > customized. This form can also be customized, but the customization is
> > > not loaded. This form has many fields we do not want to be available to
> > > our users.
> > > It looks like the Epicor.Mfg.UI.CustomerEntry.dll loads the form based
> > > on whether or not a customer has been selected. When there is not a
> > > customer Id a Customer Maintenance Form loads, and when the customer is
> > > selected the Ship To Maintenance form loads.
> > > Is there a way to remove/disable the Open With menu item? We tried
> > > setting the "Like" extended property to an empty value on
> > > OrderHed.ShipToNum column, but the menu item is still displayed.
> > > Thanks in advance,
> > > Ray
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> > (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
Hi All,
We have an extensive customization to the Customer Entry Form, including the Ship To details tab. It is located under Sales Management->Order Management->Setup, with menu Id OMMT1110.
In Order Entry, on the Ship To field there is a Right-Click "Open With...->Customer Ship To Entry" menu item, which when traced it looks like it calls the menu item above, OMMT1110.
The problem is it loads a Ship To Maintenance Form (App.CustomerEntry.ShipToEntryForm) not the Customer Entry form we customized. This form can also be customized, but the customization is not loaded. This form has many fields we do not want to be available to our users.
It looks like the Epicor.Mfg.UI.CustomerEntry.dll loads the form based on whether or not a customer has been selected. When there is not a customer Id a Customer Maintenance Form loads, and when the customer is selected the Ship To Maintenance form loads.
Is there a way to remove/disable the Open With menu item? We tried setting the "Like" extended property to an empty value on OrderHed.ShipToNum column, but the menu item is still displayed.
Thanks in advance,
Ray
Use Context Menu maintenance, in System-> Utils and find what the Like item
in that field is, then set the correct MENU for it.
Erm.. that sounds confusing, hopefully you figure out what I meant,
otherwise, shoot me back and I'll try to re-explain.
*Jose C Gomez*
*Software Engineer*
*checkout my new blog <http://www.usdoingstuff.com> *
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
On Mon, Jun 25, 2012 at 9:22 AM, zanniebelle <rwatson@...> wrote:
> Hi All,
> users.
> Thanks in advance,
> Ray
Hi Jose,
That's part of the problem; there is not a context menu item for OrderHed.ShipToNum. It looks like this context menu is built into the form and is not part of the data driven menu items.
Do you know where the context menu items are stored in Sql Server?
Ray
> *Jose C Gomez*
> *Software Engineer*
> E: jose@...
> > Hi All,
> > users.
> > Thanks in advance,
> > Ray
Brian.
Of zanniebelle
Open With...
Hi All,
our users.
Thanks in advance,
Ray
Hi Brian,
Ray
> Brian.
> Of zanniebelle
> Open With...
> Hi All,
> our users.
> Thanks in advance,
> Ray
Hope that helps,
Ted
Hi Brian,
Ray
> Brian.
> Of zanniebelle
> Open With...
> Hi All,
> our users.
> Thanks in advance,
> Ray
> Hope that helps,
> Ted
> From: zanniebelle <rwatson@...>
> Hi Brian,
> Ray
> >Â
> > Brian.
> >Â
> > Of zanniebelle
> > Open With...
> >Â
> >Â
> > Hi All,
> > our users.
> > Thanks in advance,
> > Ray
