Hello All,
We have been experiencing issues during MRP. The above error is nearly always the culprit. It has gotten to the point where it is a coin flip on whether our Net Change or Regen completes. For our setup we have a SQL server and two App Servers on separate machines. Our MRP runs on the second App Server, but we have attempted to run it on the first App Server with the same results.
We have implemented various Method and Data Directives in the past months, so have begun to look into those. On our Pilot server, we have performed the steps in this article to disable all Method and Data Directives. This still failed two out of three times:
One interesting aspect in this case is that a second, smaller, company that we run MRP for from the same setup fails with the same error. It does not occur with near the same frequency. We have not implemented the Directives in this company,and it is not near as large from a part and job perspective.
A sample stack trace from MRP is below. The MRP Method called when this error occurs varies. Any ideas on where we should focus our attention? We would think it has something to do with the new Method and Data Directives put in place, but cannot say for sure. Has anybody else seen a similar error, and what was the ultimate cause? Thanks in advance for the help and Happy Holidays!
13:16:06 The underlying provider failed on EnlistTransaction.
13:16:06 The requested operation cannot be completed because the connection has been broken.
13:16:06 at System.Data.Entity.Core.EntityClient.EntityConnection.EnlistTransaction(Transaction transaction)
at System.Data.Entity.Core.Objects.ObjectContext.EnsureContextIsEnlistedInCurrentTransaction[T](Transaction currentTransaction, Func`1 openConnection, T defaultValue)
at System.Data.Entity.Core.Objects.ObjectContext.EnsureConnection(Boolean shouldMonitorTransactions)
at System.Data.Entity.Core.Objects.ObjectContext.ExecuteInTransaction[T](Func`1 func, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction, Boolean releaseConnectionOnSuccess)
at System.Data.Entity.Core.Objects.ObjectContext.SaveChangesToStore(SaveOptions options, IDbExecutionStrategy executionStrategy, Boolean startLocalTransaction)
at System.Data.Entity.Core.Objects.ObjectContext.SaveChangesInternal(SaveOptions options, Boolean executeInExistingTransaction)
at Ice.IceDataContext.SaveChanges(SaveOptions options) in C:\_Releases\ICE\ICE3.2.200.11\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 356
at Ice.IceDataContext.Validate[TLinqRow](TLinqRow row) in C:\_Releases\ICE\ICE3.2.200.11\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 317
at Ice.IceDataContext.Release[TEntity](TEntity& entity) in C:\_Releases\ICE\ICE3.2.200.11\Source\Framework\Epicor.System\Data\IceDataContext.cs:line 269
at Erp.Internal.Lib.DeferredUpdate.PostPQDemand(String pComp, String pPartNum, String pWhseCode, Decimal pDemandQty, Decimal pReservedQty, Decimal pAllocatedQty, Decimal pPickingQty, Decimal pPickedQty, Decimal pUnfirmQty, String pUOM, String pDemandType) in c:\_Releases\ERP\RL10.2.200.0\Source\Server\Internal\Lib\DeferredUpdate\DeferredUpdate.cs:line 547
at Erp.Internal.Lib.JobMtlBackOut._BackOut(String ipCompany, String ipPartNum, String ipWarehouseCode, String ipIUM, Decimal ipRequiredQty, Decimal ipIssuedQty, Boolean ipJobFirm) in C:\_Releases\ERP\UD10.2.200.11\Source\Server\Internal\Lib\JobMtlShared\BackOut\BackOut.cs:line 86
at Erp.Internal.MR.MrpExp.deleteUnfirmJob(String vPlantList) in C:\_Releases\ERP\UD10.2.200.11\Source\Server\Internal\MR\MrpExp\MrpExp.cs:line 1989
at Erp.Internal.MR.MrpExp.main_block(List`1 ttMrpProcRows, List`1 ttMrpQueueRows) in C:\_Releases\ERP\UD10.2.200.11\Source\Server\Internal\MR\MrpExp\MrpExp.cs:line 2620
at Erp.Internal.MR.MrpExp.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ERP\UD10.2.200.11\Source\Server\Internal\MR\MrpExp\MrpExp.cs:line 919
13:16:06 at System.Data.SqlClient.SqlInternalConnectionTds.ExecuteTransaction(TransactionRequest transactionRequest, String name, IsolationLevel iso, SqlInternalTransaction internalTransaction, Boolean isDelegateControlRequest)
at System.Data.SqlClient.SqlDelegatedTransaction.Initialize()
at System.Transactions.TransactionStatePSPEOperation.PSPEInitialize(InternalTransaction tx, IPromotableSinglePhaseNotification promotableSinglePhaseNotification, Guid promoterType)
at System.Transactions.TransactionStateActive.EnlistPromotableSinglePhase(InternalTransaction tx, IPromotableSinglePhaseNotification promotableSinglePhaseNotification, Transaction atomicTransaction, Guid promoterType)
at System.Transactions.Transaction.EnlistPromotableSinglePhase(IPromotableSinglePhaseNotification promotableSinglePhaseNotification, Guid promoterType)
at System.Transactions.Transaction.EnlistPromotableSinglePhase(IPromotableSinglePhaseNotification promotableSinglePhaseNotification)
at System.Data.SqlClient.SqlInternalConnection.EnlistNonNull(Transaction tx)
at System.Data.SqlClient.SqlInternalConnection.Enlist(Transaction tx)
at System.Data.SqlClient.SqlInternalConnection.EnlistTransaction(Transaction transaction)
at System.Data.SqlClient.SqlConnection.EnlistTransaction(Transaction transaction)
at Epicor.Data.Provider.EpiConnection.EnlistTransaction(Transaction transaction) in C:\_Releases\ICE\ICE3.2.200.11\Source\Framework\Epicor.System\Data\EpiProvider2\EpiConnection.cs:line 208
at System.Data.Entity.Infrastructure.Interception.InternalDispatcher`1.Dispatch[TTarget,TInterceptionContext](TTarget target, Action`2 operation, TInterceptionContext interceptionContext, Action`3 executing, Action`3 executed)
at System.Data.Entity.Infrastructure.Interception.DbConnectionDispatcher.EnlistTransaction(DbConnection connection, EnlistTransactionInterceptionContext interceptionContext)
13:16:06 Unexpected Error - Cancelling MRP - MrpExp
at Erp.Internal.MR.MrpExp.abortMRP(Int64 instanceTaskNum) in C:\_Releases\ERP\UD10.2.200.11\Source\Server\Internal\MR\MrpExp\MrpExp.cs:line 985
at Erp.Internal.MR.MrpExp.RunProcess(Int64 instanceTaskNum, String outputFileName) in C:\_Releases\ERP\UD10.2.200.11\Source\Server\Internal\MR\MrpExp\MrpExp.cs:line 952
