Yeah, I was wondering what version, because in 607B, this is not an issue.
It must be a known bug in 604.
M
On Behalf Of Adrian Lauchlan
Sent: Tuesday, November 19, 2013 5:33 PM
Subject: RE: [Vantage] RE: MRP not creating PO Suggestions
I have been doing some more testing on this and the strange thing is that if a supplier has been entered in the PartPlant.Vendor field under Purchasing on the Plant Detail tab of Part then MRP fails to generate a PO suggestion. Remove it and it generates a PO Suggestion. I have yet to work out exactly what it is about the supplier that causes this to happen.
To answer your questions
1. Job is engineered and scheduled
2. Not checked as make direct
3. I didn't check multi level pegging
4. parts are checked as quantity bearing
Parts within the same BoM are having PO suggestions made if this Vendor field is empty and those with an entry for a particular supplier are not
I have noticed also that the MRP recalc field is ticked for the item and am now running MRP as Net Change to see what happens and whether the field gets cleared
On Behalf Of nhoyt111@...
Sent: 19 November 2013 18:17
Subject: [Vantage] RE: MRP not creating PO Suggestions
We're on 905607B but once upon a time mrp on 904 something. A few thoughts:
1. Are jobs engineered? Are they scheduled?
2. Any chance matl checked as make direct on job matl detail tab?
3. Do you have multi level pegging checked on MRp run?
4. Are parts checked as quantity bearing?
Nancy
