MRP Processor Error
There is something wrong with the Part.  Likely it is a Manufactured part.
Check that all plants have a PartRev record.
Mfgsys must have a partrev record and then all other Plants must have an Alt Method.
Check that the method for that plant is good.  Resources, operations.
If using Alt Methods, make sure that you have the correct Primary Alt Method.
Did you just upg to 702?
At the end of the MRP Process 4 log, you probably have an error like this::
15:14:16 Copying BOM from Part:50-70911-000 Rev:B to Job:UF000000001131.
That will be at the end of the log.  You should be able to tell by the size of the file you are looking at.
From the Main MRP Log:
4:48:20 Scheduling Jobs...
14:48:20 Building PartList Level: 0
14:53:41 Building PartList Level: 1
15:06:40 Building PartList Level: 2
16:14:21 Process 6 not responding.  Abandoned during process 'Processing Part~50-70911-000'
16:14:21 Building PartList Level: 3
16:18:57 Building PartList Level: 4
16:19:31 Building PartList Level: 5
It takes 1 hour before that processor times out, but all the other parts are re-routed to the other processors.
Miguel A. Santillan
Compass Manufacturing Systems
Sent: Tuesday, September 30, 2014 8:23 AM
Subject: [Vantage] MRP Processor Error
We're on 9.05.702
We run MRP each night with 4 processors (Net Change M-Th, Regen F).  Last night MRP 4 Processor had an error and stopped.  Here's the log file error message:
20:18:06 Process 4 not responding.  Abandoned during process 'Processing Part~050EF0007'
Can anyone tell me if when an error like this happens, do all unprocessed parts get routed to the other three processors, or do some parts fail to get processed because the one processor stops running?
We're on 9.05.702
Its been my experience that all unprocessed parts just stop they do not get rerouted
On Tuesday, September 30, 2014 11:22 AM, "iarouleur@... [vantage]" <vantage@yahoogroups.com> wrote:
<div id="ygrps-yiv-705883816yiv1379262656ygrp-text">
  <div><span>We&#39;re on 9.05.702</span></div><div><span><br clear="none"></span></div><div><span>We run MRP each night with 4 processors (Net Change M-Th, Regen F).&nbsp; Last night MRP 4 Processor had an error and stopped.&nbsp; Here&#39;s the log file error message: </span></div><div><span><br clear="none"></span></div><div><span>20:18:06 Process 4 not responding.&nbsp; Abandoned during process &#39;Processing Part~050EF0007&#39;&nbsp; </span></div><div><span><br clear="none"></span></div><div><span>Can anyone tell me if when an error like this happens, do all unprocessed parts get routed to the other three processors, or do some parts fail to get processed because the one processor stops running?</span></div>
</div>
<div style="color:#fff;height:0;"></div></div>
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656 -- #ygrps-yiv-705883816yiv1379262656ygrp-mkp { border:1px solid #d8d8d8;font-family:Arial;margin:10px 0;padding:0 10px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mkp hr {
border:1px solid #d8d8d8;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mkp #ygrps-yiv-705883816yiv1379262656hd {
color:#628c2a;font-size:85%;font-weight:700;line-height:122%;margin:10px 0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mkp #ygrps-yiv-705883816yiv1379262656ads {
margin-bottom:10px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mkp .ygrps-yiv-705883816yiv1379262656ad {
padding:0 0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mkp .ygrps-yiv-705883816yiv1379262656ad p {
margin:0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mkp .ygrps-yiv-705883816yiv1379262656ad a {
color:#0000ff;text-decoration:none;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-sponsor #ygrps-yiv-705883816yiv1379262656ygrp-lc {
font-family:Arial;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-sponsor #ygrps-yiv-705883816yiv1379262656ygrp-lc #ygrps-yiv-705883816yiv1379262656hd {
margin:10px 0px;font-weight:700;font-size:78%;line-height:122%;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-sponsor #ygrps-yiv-705883816yiv1379262656ygrp-lc .ygrps-yiv-705883816yiv1379262656ad {
margin-bottom:10px;padding:0 0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656actions {
font-family:Verdana;font-size:11px;padding:10px 0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656activity {
background-color:#e0ecee;float:left;font-family:Verdana;font-size:10px;padding:10px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656activity span {
font-weight:700;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656activity span:first-child {
text-transform:uppercase;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656activity span a {
color:#5085b6;text-decoration:none;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656activity span span {
color:#ff7900;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656activity span .ygrps-yiv-705883816yiv1379262656underline {
text-decoration:underline;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656attach {
clear:both;display:table;font-family:Arial;font-size:12px;padding:10px 0;width:400px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656attach div a {
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656attach img {
border:none;padding-right:5px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656attach label {
display:block;margin-bottom:5px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656attach label a {
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 blockquote {
margin:0 0 0 4px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656bold {
font-family:Arial;font-size:13px;font-weight:700;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656bold a {
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 dd.ygrps-yiv-705883816yiv1379262656last p a {
font-family:Verdana;font-weight:700;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 dd.ygrps-yiv-705883816yiv1379262656last p span {
margin-right:10px;font-family:Verdana;font-weight:700;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 dd.ygrps-yiv-705883816yiv1379262656last p span.ygrps-yiv-705883816yiv1379262656yshortcuts {
margin-right:0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656attach-table div div a {
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656attach-table {
width:400px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656file-title a, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656file-title a:active, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656file-title a:hover, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656file-title a:visited {
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656photo-title a, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656photo-title a:active, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656photo-title a:hover, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div.ygrps-yiv-705883816yiv1379262656photo-title a:visited {
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 div#ygrps-yiv-705883816yiv1379262656ygrp-mlmsg #ygrps-yiv-705883816yiv1379262656ygrp-msg p a span.ygrps-yiv-705883816yiv1379262656yshortcuts {
font-family:Verdana;font-size:10px;font-weight:normal;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656green {
color:#628c2a;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656MsoNormal {
margin:0 0 0 0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 o {
font-size:0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656photos div {
float:left;width:72px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656photos div div {
border:1px solid #666666;height:62px;overflow:hidden;width:62px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656photos div label {
color:#666666;font-size:10px;overflow:hidden;text-align:center;white-space:nowrap;width:64px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656reco-category {
font-size:77%;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656reco-desc {
font-size:77%;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 .ygrps-yiv-705883816yiv1379262656replbq {
margin:4px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-actbar div a:first-child {
margin-right:2px;padding-right:5px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mlmsg {
font-size:13px;font-family:Arial, helvetica, clean, sans-serif;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mlmsg table {
font-size:inherit;font:100%;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mlmsg select, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 input, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 textarea {
font:99% Arial, Helvetica, clean, sans-serif;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mlmsg pre, #ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 code {
font:115% monospace;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mlmsg * {
line-height:1.22em;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-mlmsg #ygrps-yiv-705883816yiv1379262656logo {
padding-bottom:10px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-msg p a {
font-family:Verdana;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-msg p#ygrps-yiv-705883816yiv1379262656attach-count span {
color:#1E66AE;font-weight:700;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-reco #ygrps-yiv-705883816yiv1379262656reco-head {
color:#ff7900;font-weight:700;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-reco {
margin-bottom:20px;padding:0px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-sponsor #ygrps-yiv-705883816yiv1379262656ov li a {
font-size:130%;text-decoration:none;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-sponsor #ygrps-yiv-705883816yiv1379262656ov li {
font-size:77%;list-style-type:square;padding:6px 0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-sponsor #ygrps-yiv-705883816yiv1379262656ov ul {
margin:0;padding:0 0 0 8px;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-text {
font-family:Georgia;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-text p {
margin:0 0 1em 0;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-text tt {
font-size:120%;}
#ygrps-yiv-705883816 #ygrps-yiv-705883816yiv1379262656 #ygrps-yiv-705883816yiv1379262656ygrp-vital ul li:last-child {
border-right:none !important;}
