Multiple Part Number Work Orders
Actually, I did not mean to make it a true "phantom" part in Vantage as
opposed to a manufactured or purchased part. I don't see an advantage in
doing that. Just make the ficticious level 0 part a manufactured part with
as many sub assemblies as you need.
Greg
Sent: Thursday, July 17, 2003 4:15 PM
Subject: RE: [Vantage] Multiple Part Number Work Orders
Greg,
Your solution sounds great. Kathy's does too. Thank you to both of you.
I'm trying to set up a top level phantom assembly with 3 sub-assemblies,
which are the real parts that we're completing. The phantom doesn't allow a
BOM with sub-assemblies. Do you have a way around this?
Bruce
Sent: Friday, July 11, 2003 1:28 PM
To: 'vantage@yahoogroups.com'
You could also make something like a 'Phantom' part number / BOM for a
non-existent level 0 part number that has three different level 1
sub-assemblies, one for each (different wood) part number. Each time you
create a job from it, you'll have to adjust the "qty per parent" of each
level 1 part so that you're ordering the amount of each part you want to
make. That way, the job will generate requirements for each of the
different raw material wood types.
The level 0 part's operation does not need to be anything special or even
have a labor standard. The operators can report against the same job number
for the whole run but need to report against the three different level 1
'assemblies" (eg: ASM =Cherry, ASM 2 = Oak, etc). You would then receive
the level 1 assemblies into stock rather than the level 0 part.
Sound complicated but it's not too bad. Depends on your preference in
scheduling and reporting versus separate jobs for each different wood.
Greg Clauser
General Manager
Lakin General Corporation
773-871-9604 FAX: 773-871-1265
gclauser@... <mailto:gclauser@...>
Sent: Friday, July 11, 2003 6:45 AM
One way to do this is prior to moving the finished parts to inventory,
split the job two times. Change the part number for the two split jobs
to be what you want and keep the original job as the third part. It may
sound like a lot of work but it only takes seconds to split the job.
You get the costs proportionately based on number of pcs split. I hope
this makes sense, we use this procedure occasionally and it works well.
Kathy Hambleton
Electron Energy Corp
Sent: Thursday, July 10, 2003 8:06 PM
Bruce,
Out of the box, long and short of it is one job order, one part number.
If you can live with one part number for all the different color
configurations, then you can do it in one job. However, you will not be
able to receive it to stock as separate part numbers directly from the
job.
Our practice is to have a separate job order for each configuration of
cabinets. It's cleaner that way.
HTH,
Gil Amilbangsa
Australian Healthcare Equipment - Murphy Furniture
gil.amilbangsa@...
Sent: Friday, 11 July 2003 9:51 AM
Subject: [Vantage] Multiple Part Number Work Orders
We process products of exactly the same design but using different
wood species, such as a molding in maple, oak and cherry. All
operations are identical but the raw material issued is maple, oak
and cherry in proportion to the variety of finished products and the
finished products need to be stocked separately depending on the
variety of wood.
I'd like to process one job, issue different kinds of wood and
complete several differnt part numbers from the same job. Has anyone
done this? How can this work?
Bruce
Yahoo! Groups Sponsor
ADVERTISEMENT
< http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=1705
<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=1705>
<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=1705> >
007183:HM/A=1663535/R=0/SIG=11ps6rfef/* http://www.ediets.com/start.cfm?c
<http://www.ediets.com/start.cfm?c>
< http://www.ediets.com/start.cfm?c <http://www.ediets.com/start.cfm?c> >
ode=30504&media=atkins> click here
< http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egrou
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egrou>
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egrou> >
pmail/S=:HM/A=1663535/rand=517402399>
< http://groups.yahoo.com/group/vantage/files/.
<http://groups.yahoo.com/group/vantage/files/.> >
< http://groups.yahoo.com/group/vantage/messages
<http://groups.yahoo.com/group/vantage/messages> >
< http://groups.yahoo.com/group/vantage/links
<http://groups.yahoo.com/group/vantage/links> >
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> <
http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > > .
ADVERTISEMENT
http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=17050071
<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=17050071
http://www.ediets.com/start.cfm?code=3050
<http://www.ediets.com/start.cfm?code=3050>
http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmai
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmai
l/S=:HM/A=1663535/rand=984452632>
< http://docs.yahoo.com/info/terms/ <http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=170500718
3:HM/A=1663535/R=0/SIG=11ps6rfef/*http://www.ediets.com/start.cfm?code=30504
83:HM/A=1663535/R=0/SIG=11ps6rfef/*http://www.ediets.com/start.cfm?code=3050
4&media=atkins> &media=atkins> click here
http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmail
/S=:HM/A=1663535/rand=772025696
l/S=:HM/A=1663535/rand=772025696> >
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <
ADVERTISEMENT
l/S=:HM/A=1663535/rand=356982136>
variety of wood.
Bruce
Bruce,
Out of the box, long and short of it is one job order, one part number. If you can live with one part number for all the different color configurations, then you can do it in one job. However, you will not be able to receive it to stock as separate part numbers directly from the job.
Our practice is to have a separate job order for each configuration of cabinets. It's cleaner that way.
HTH,
Gil Amilbangsa
gil.amilbangsa@...
variety of wood.
Bruce
ADVERTISEMENT
<http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=1705007183:HM/A=1663535/R=0/SIG=11ps6rfef/*http://www.ediets.com/start.cfm?code=30504&media=atkins> click here
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmail/S=:HM/A=1663535/rand=517402399>
Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Kathy Hambleton
Bruce,
job.
HTH,
Gil Amilbangsa
gil.amilbangsa@...
variety of wood.
Bruce
ADVERTISEMENT
Greg Clauser
General Manager
Kathy Hambleton
Bruce,
job.
HTH,
Gil Amilbangsa
gil.amilbangsa@...
variety of wood.
Bruce
ADVERTISEMENT
ADVERTISEMENT
Greg,
I'm trying to set up a top level phantom assembly with 3 sub-assemblies, which are the real parts that we're completing. The phantom doesn't allow a BOM with sub-assemblies. Do you have a way around this?
Bruce
Greg Clauser
General Manager
Kathy Hambleton
Bruce,
job.
HTH,
Gil Amilbangsa
gil.amilbangsa@...
variety of wood.
Bruce
ADVERTISEMENT
< http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=1705>
< http://www.ediets.com/start.cfm?c>
< http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egrou>
< http://groups.yahoo.com/group/vantage/files/.>
< http://groups.yahoo.com/group/vantage/messages>
< http://groups.yahoo.com/group/vantage/links>
< http://docs.yahoo.com/info/terms/ < http://docs.yahoo.com/info/terms/> > .
ADVERTISEMENT
< http://rd.yahoo.com/M=194081.3551198.4824677.1261774/D=egroupweb/S=17050071
83:HM/A=1663535/R=0/SIG=11ps6rfef/* http://www.ediets.com/start.cfm?code=3050
< http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmai
< http://docs.yahoo.com/info/terms/> .
ADVERTISEMENT
<http://us.adserver.yahoo.com/l?M=194081.3551198.4824677.1261774/D=egroupmail/S=:HM/A=1663535/rand=772025696>
