Waffqle. You helped me with this customization a few weeks ago. I wanted to
know, after the update, how can I have the code close the open active form
or refresh in a way that the changes are effective. Apparently it does work
but you don't see the change until you close out of the window or select
another entry and return to the one that was just saved.
Best Regards,
Â
Herby Dallard
Information Technology Engineer
Endicott Research Group
hdallard@...
607-754-9187 ext. 3078
www.ergpower.com
Waffqle
Sent: Tuesday, July 12, 2011 11:40 AM
Subject: Re: [Vantage] Need a Customization tip
You want to use the Form Event Wizard and select the 'AfterAdapterMethod'
type and the appropriate adapter. The adapter name should be 'CRMCall' or
something similar, you'll recognize it. It should produce code that looks
like whats below. Your code will look a bit different as I stripped all the
comments and white space for the sake of readability.
If you look at the case statement at the bottom, you'll see where it catches
the 'Update' event. That is where your going to want to call the function
that disables your field and/or whatever else you'd like to do. You can also
add more cases to catch other adapter methods. For example, enabling the
text when a different record is loaded.
Module Script
Private WithEvents oTrans_adapter As EpiBaseAdapter
Sub InitializeCustomCode()
oTrans_adapter = csm.TransAdaptersHT("oTrans_adapter")
AddHandler oTrans_adapter.AfterAdapterMethod, AddressOf
oTrans_adapter_AfterAdapterMethod
End Sub
Sub DestroyCustomCode()
RemoveHandler oTrans_adapter.AfterAdapterMethod, AddressOf
oTrans_adapter = Nothing
End Sub
Private Sub oTrans_adapter_AfterAdapterMethod(ByVal sender As Object, ByVal
args As AfterAdapterMethodArgs)
Select Case args.MethodName
Case "Update"
Case Else
End Select
End Sub
End Module
On Tue, Jul 12, 2011 at 11:30 AM, Herby Dallard
<hdallard@...>wrote:
*Waffqle Driggers*
*High End Dev, System Design, Profit Drinking
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
Best Regards,
Â
Herby Dallard
hdallard@...
www.ergpower.com
Waffqle
Module Script
End Sub
End Sub
Case "Update"
Case Else
End Select
End Sub
End Module
> **any
> ItÂ’s the CRMCall table. The problem is we need the field to be editable
> until the current record transaction is saved regardless of lost focus or
> got focus. Once the record is saved we need it triggered. I do not have
> examples on using the Update Event. We are using Vantage 804B and are--
> limited to events such as Close, Load, etc... If you have an update event
> definition /example please include it in your reply.
> Thanks.
> Best Regards,
> Herby Dallard
> hdallard@...
> www.ergpower.com
> Of
> Waffqle
> Sent: Tuesday, July 12, 2011 8:46 AM
> Rather than hooking into an event for the dataview, try hooking into
> GetByID
> and/or Update and setting it read only if there is already data in the
> field.
> On Tue, Jul 12, 2011 at 8:23 AM, Steven Gotschall
> <sgotschall@...>wrote:
> > Depends on the form you are talking about. If it is a sales order,
> > Invoice, Quote, etc. then you could set the field's extended attribute
> > Readonly when the OrderNum (or whatever) changes from 0 to a non zero
> value.
> > From: Herby Dallard <hdallard@...>
> > Sent: Monday, July 11, 2011 5:10 PM
> > Subject: [Vantage] Need a Customization tip
> > Hello all. I would like to have a user editable text box field become
> read
> > only after the user saves the record. I am able to do this with
> > EpiViewNotification but it happens right after the user leaves the
> textbox
> > to input data in another field. Does anyone have a sample code of an
> event
> > I
> > would have to code this under to trigger the read only mode after record
> > has
> > been saved or updated?
> > Best Regards,
> > Herby Dallard
> > hdallard@...
> > www.ergpower.com <http://www.ergpower.com/>
> *Waffqle Driggers*
> *:: 904.962.2887*
> *:: waffqle@...*
> *:: NO FAXES*
*Waffqle Driggers*
*:: 904.962.2887*
*:: waffqle@...*
*:: NO FAXES*
