New Part Entry Blank Title 59458
The change log exists in earlier versions as well but must be activated in
the Business Activity Manager in the Utilities menu. I think it was
introduced in 5.1. However use it with caution! Select logging only for
those entries you are truly interested in. The associated horror story with
that is that a Vantage user activated change logs for all fields and in a
couple of days the database grew from a few Megs to multiple Gigs!
Stan
_____
Knowlton,Keith
Sent: Thursday, September 27, 2007 8:04 AM
Subject: RE: [Vantage] New Part Entry
Sure, if your using 8.01 there is a Change Log Viewer, this will
document the date and who created the new record, even if there is not a
revision created.
From: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
[mailto:vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com] On
Behalf
Of Lori Gustafson
Sent: Wednesday, September 26, 2007 9:42 AM
To: vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com
Subject: [Vantage] New Part Entry
Does anyone know if there is a way to identify who setup a new part
number in Vantage and the date it was setup? This would just be a part
number entry without a revision.
Lori Gustafson
Information Resources
Precision, Inc.
763-852-6718
________________________________________________________
This e-mail is intended solely for the person or entity to which it is
addressed and may contain confidential and/or privileged information.
Any review, dissemination, copying, printing, forwarding or other use of
this e-mail by persons or entities other than the addressee is
prohibited. If you have received this e-mail in error, please contact
the sender immediately and delete the material from your computer.
Opinions, conclusions and other information in this message that do not
relate to the official business of Altra Industrial Motion, Inc. shall
be understood as neither given or endorsed by it.
Lori Gustafson
Precision, Inc.
763-852-6718
Not that I know of, unless a change log (BAM) was turned on.
Paul
Of Lori Gustafson
Lori Gustafson
Precision, Inc.
763-852-6718
If you have the change log turned on, you would see an entry in the first
date listed for that part number. So for this example, on 5/9/2006
"SAnderson 11:37:43 New Record"
This is true for both 6.1 and 8.0
Amy O'Malley
Manufacturing Process Engineer
Synovis Interventional Solutions
>Lori Gustafson
>Precision, Inc.
>763-852-6718
You might be able to use Business Activity Manager and define the fields you want to monitor.
Then you would goto Change Log under Actions for that part and see what information is there.
Lori Gustafson
Precision, Inc.
763-852-6718
Catch up on fall's hot new shows on Yahoo! TV. Watch previews, get listings, and more!
revision created.
Of Lori Gustafson
Lori Gustafson
Precision, Inc.
763-852-6718
That is true, but it has to be turned for it to work.
Of Knowlton,Keith
revision created.
Behalf
Of Lori Gustafson
Lori Gustafson
Precision, Inc.
763-852-6718
