Wayne,
I also just got the new Merant driver, and couldn't figure out how to get it
running. I opened a service call, and was emailed the instructions.
Believe it or not, the instructions worked. You should be able to get them
from Customer Service.
Sent: Thursday, July 20, 2000 9:34 AM
To: vantage@egroups.com
Subject: Re: [Vantage] ODBC for Vantage 3.0 and 4.0 on same machine?
At 11:16 AM 7/20/2000 , you wrote:
You can write some "one or the other" logic into the Autoexec.Bat file, or
use Dos style boot menus on Win9x to select environment variables at
boot. I don't know where the ODBC settings are stored, but there are ways
to swap .Ini files and registry settings back and forth.
BTW... Does Epicor or anyone else have up to date installation instructions
for Merant 3.6 / Progress 9 ? I just received the 3.6 driver, and would
like to use it with my test 4.0/9.0B server. I *think* that 98% of the
couple dozen documents RE this on EraNet are obsolete? This is my first
experience with Progress & ODBC.
Is it true that the new one loads stand alone, and this "mini
client" mentioned by Epicor is no longer needed?
-Thanks,
Wayne Cox
Respond.com - Technology Solutions for your Business!
http://click.egroups.com/1/6828/13/_/411782/_/964107395/
>We are installing Vantage 4.0 alongside 3.0 for evaluation purposes.time...
>...workstation can run both 4.0 and 3.0 at the same time, the workstation
>can only install ODBC drivers for 3.0 OR 4.0, but not both at the same
-Thanks,
Wayne Cox
