[off-topic] Visual Basic Question - rounding up?
Thanks Mark and Wayne, I had been searching for a command like 'roundup' in
excel. With your help, it's working now!
I am setting a field value based on equation. The resulting files needs to
be an integer. The caluculation may result ina fraction. I want the
calculated number to always round up to the next integer value to set the
field. (ex. 4.2 = 5, 4.6 = 5, 4.0 = 4). If anyone know how to do this, I
would GREATLy appreciate it!!!
Use the truncate command to compare the truncated value to the actual.
For example:
IF FIX(ActualVal) <> ActualVal then
ActualVal = FIX(Actualval + 1).
That should round up all decimal values to the next largest number for
all positive numbers. If you are dealing with negative numbers you might
have to use the INT() function to get the desired result.
Mark Charamut
President
Caesar Development Services, LLC
mcharamut@...
www.caesardev.com
(860) 667-4774 x20
From: sarah.vareschi@... [mailto:sarah.vareschi@...]
Sent: Thursday, April 04, 2002 2:22 PM
Subject: [Vantage] [off-topic] Visual Basic Question - rounding up?
to
the
I
Your use of Yahoo! Groups is subject to
http://docs.yahoo.com/info/terms/
Many languages have a function called Ceiling to do exactly what you
describe. VB lacks such a function. Here's the code for a home-grown
version.
Public Function Ceiling(sngNumberIn As Single) As Integer
Dim intInputToInteger
intInputToInteger = Int(sngNumberIn)
If sngNumberIn = intInputToInteger Then
Ceiling = intInputToInteger
Else
Ceiling = intInputToInteger + 1
End If
End Function
Hope this helps ...
Larry Kurtze
Aspacia Systems Inc
27 North Wacker Drive, Suite 422
Chicago IL 60606
866.566.9600, Fax 312.803.0730
www.aspacia.com
lkurtze@...
Sent: Thursday, April 04, 2002 1:22 PM
to
the
I
As far as I know there isn't a specific function to do exactly what you
want, but the following will work:
If Int(YourNum) = (YourNum) Then
Int(YourNum)
Else
Int(YourNum) + 1
End If
Int takes the integer portion of the number and ignores the rest. The
integer portion of 4.0 is 4. If this equals 4.0 (and it does) then you want
4 as your value. If your number is 4.3, the integer portion is 4, but 4
doesn't equal 4.3 so you take the integer portion, which is 4, and add 1 to
round it to the next whole number.
Hope this helps,
Christopher Gitzlaff
Manager - Information Systems & Technology
Major Industries, Inc.
Phone: 715-842-4616
Fax: 715-848-3336
I usually use something like: X = Int( X + 0.99 )
[you might have to correct the function name for the Int() thing - I
haven't used VB in years, but most everything calls it that]
-Wayne
