OFF TOPIC - Windows Server 2003 Subfolder Security
John,
Thanks for the reply. I will try this also.
Todd:
Also Todd Anderson your the man thanks for the phone call.
You can search a file structure using windows explorer then search for a
folder name such as "Confidential" then cherry pick folders or select
all folders, from there right click and select "Properties" and the
"Security's" Tab. Uncheck the "inherit permissions", choice of copy or
remove permission, I choose copy because I also have administrative and
backup permission. I then add and delete groups and also check "Replace
permission entries on child objects" then apply.
Again this shows the power of this group.
Thanks to all who responded.
Patrick Winter
Of John Sage
Sent: Friday, December 01, 2006 10:15 AM
Subject: Re: [Vantage] OFF TOPIC - Windows Server 2003 Subfolder
Security
Patrick,
You'll want to use the CACLS command-line utility.
From the AccountsReceivable\Customers folder:
CACLS Confidential /T /G Group4:F
This command will traverse all subfolders, looking for a folder named
"Confidential" (/T). For each matching folder, it will replace the
current ACL and grant Full Access to Group 4 (/G).
There are other command-line options for CACLS that you'll want to
review. Type CACLS from a command prompt for a help listing.
CACLS can also be used to list ACLs.
have fun,
john
Winter, Patrick wrote:
> Scott,
> Ok, you understand where I'm at, that makes sense but what I was
> wondering is there a way to do this across the board without doing
each
> folder one at a time when they are created?
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
This is a question on Windows Server 2003 Subfolder Security.
I control file security for general network shares with groups, here is
a generic example:
Shared folder = AccountsReceivable
Group 1 = AR view only group
Group 2 = AR publisher group
Group 3 = AR Editors group
Each group used in securing this folder would then have the appropriate
security settings.
Also everything below the shard folder "AccountsReceivable" would be set
inherit permission from the parent, etc...
If within the shared folder "AccountsReceivable" we create folders for
customers.
Acme
Company2
Company3
Etc...
If I create the same subfolder under each Customer called say
"Confidential", can I somehow set this folder to a different security
group, say "Group4"
Group 4 = Accounting Controller publisher Group.
I hope I have explained this properly.
Patrick
Patrick,
For Sub-Folders that you do not want to inherit security from a Parent
Folder, uncheck the "Allow inheritable permissions from the parent to
propagate to this object and all child objects. Include these with entries
explicitly defined here.".
This is found in the Security Tab of the Shared folder by clicking the
Advanced button.
You will be given the choice to Copy or Remove the Security. Read the
descriptions and it will explain what both of those mean.
Scott Litzau, MCP
Olympus Flag & Banner
Information Systems Manager
scott.litzau@...
P: 414-365-9732
F: 414-355-1931
Winter, Patrick
Sent: Friday, December 01, 2006 9:10 AM
Subject: [Vantage] OFF TOPIC - Windows Server 2003 Subfolder Security
a generic example:
security settings.
customers.
Acme
Company2
Company3
Etc...
group, say "Group4"
Patrick
Yahoo! Groups Links
Yes. You will have to disable the "Allow Inheritable Permissions from
Parent..." on the "Confidential" folder. If you use the advanced tab to
add "Group 4" you will have numerous additional options (Apply To: This
Folder only, This Folder and Files etc.). "Group 4" will also require at
least "list" privileges in the parent folders.
Jim
Of Winter, Patrick
a generic example:
security settings.
customers.
Acme
Company2
Company3
Etc...
group, say "Group4"
Patrick
Yes, after creating the folder simply set it to not inherit permissions
from the parent and then assign your rights accordingly.
Cheers,
Gerard M Wadman
Sr. Network Systems Engineer
Scandius BioMedical Inc.
11A Beaver Brook Road
Littleton, MA 01460
978/486-4088 x 124
978/486-4108 (fax)
http://www.scandius.com/
Of Winter, Patrick
Sent: Friday, December 01, 2006 10:10 AM
a generic example:
security settings.
customers.
Acme
Company2
Company3
Etc...
group, say "Group4"
Patrick
Scott,
wondering is there a way to do this across the board without doing each
My magic button would be to search for subfolders called "whatever" and
apply the following security group and don't inherit the permissions.
or
Copy a folder from a different area would when dropped it would have the
appropriate security and a of course no inherited permissions.
Also a way so search and view the folders to verify and manage this.
Patrick
PS: I guess I'm trying to see how far I can go using windows server file
system's ability without purchasing a formal document storage and
archiving system.
Of Scott Litzau
Sent: Friday, December 01, 2006 9:37 AM
Subject: RE: [Vantage] OFF TOPIC - Windows Server 2003 Subfolder
Security
Patrick,
entries
Advanced button.
Scott Litzau, MCP
scott.litzau@... <mailto:scott.litzau%40olympus-flag.com>
P: 414-365-9732
F: 414-355-1931
Behalf Of
Winter, Patrick
a generic example:
security settings.
customers.
Acme
Company2
Company3
Etc...
group, say "Group4"
Patrick
have
and
Yahoo! Groups Links
Patrick,
have fun,
john
> Scott,
You might be able to create a batch file to accomplish this. XCOPY has
a /o switch which will copy permissions. Command would look something
like:
xcopy sourcedir destinationdir /s/e/o
Use xcopy /? to find the other options.
I use xcopy when I need to move folders to a different drive and don't
want to have to worry about resetting permissions. I also use "net
share" command to create/delete shares and set share permissions.
Together in a batch file with passing it parameters makes a handy tool.
Butch
Of Winter, Patrick
Sent: Friday, December 01, 2006 7:50 AM
Security
Scott,
or
Patrick
archiving system.
Behalf
Of Scott Litzau
Security
Patrick,
entries
Advanced button.
Scott Litzau, MCP
P: 414-365-9732
F: 414-355-1931
Behalf Of
Winter, Patrick
a generic example:
security settings.
customers.
Acme
Company2
Company3
Etc...
group, say "Group4"
Patrick
have
and
<http://groups.yahoo.com/group/vantage/files/.> >
<http://groups.yahoo.com/group/vantage/messages> >
<http://groups.yahoo.com/group/vantage/links> >
Yahoo! Groups Links
