Rick,
I'm doing folder redirection on the My Documents Folders. Several of the
workstations are not allowing me to sync up to be able to work off-line too.
I just upgraded the ones in question from W98 & NT4 to W2K (not fresh
installs). I was pretty sure it's a domain security issue, but hadn't
figured it out.
I thought if it worked for you, it might tighten my domain connections too.
So far one of the three I tried so far worked. I'll try it on the rest and
see where that goes. I'll take any form of progress that I can get right
now. That was a great tip. Thanks Rick.
Gary
Sent: Friday, August 23, 2002 12:39 PM
Subject: RE: [Vantage] HELP - [off topic] Windows XP and Windows NT
Domain
Nothing happened to them, the PC just would NOT connect to the domain. I
tried many things to no avail. Then for some reason I disonnected the map
drives and it worked perfectly. Remapped and good to go.
R
Sent: Friday, August 23, 2002 10:32 AM
Subject: RE: [Vantage] HELP - [off topic] Windows XP and Windows NT Domain
Rick,
What happened with the mapped drives?
Gary Polvinale
Sent: Friday, August 23, 2002 10:28 AM
Domain
Also: If it's anything like WIN2000, disconnect any map drives first. I
had fits upgrading from WIM98 until I figured this out.
Rick Gors
Sent: Friday, August 23, 2002 9:58 AM
Domain
I set one up the other week. There is a link in the network settings
where
it will kick in a wizard to setup the network. I ended up having to
make
the XP Pro a member of the login domain so it could browse the entire
network. When I had it setup as a member of a workgroup it would only
see
that particular workgroup.
Sent: Friday, August 23, 2002 8:50 AM
Subject: [Vantage] HELP - [off topic] Windows XP and Windows NT Domain
Hi Everyone,
TGIF!!! I just purchased a new Dell computer that is running
windows XP Pro. I need to set this up on a Windows NT Domain.
I can see the network but I can not access anything on the
network. It looks like I am logged on my local instead of the
network.
Can someone call me and help with this or help me via email. I
would appreciate it. Our it person left a couple months ago and
assumed some of the responsibities but my knowledge is limited on
the network side - I am learning in progress :)
Thanks In Advance,
Dina
Vamco
(412) 963-7100 phone
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/M=232673.2253070.3709326.1774049/D=egroupweb/S=17050071
83:HM/A=1194123/R=0/*http://www.adinsdirect.com/>
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
figured it out.
Gary
Domain
R
Rick,
Gary Polvinale
Domain
Rick Gors
Domain
where
make
see
Hi Everyone,
network.
Thanks In Advance,
Dina
Vamco
ADVERTISEMENT
have
and
ADVERTISEMENT
and
have
ADVERTISEMENT
