Open App and Pass Value
Hi,
I am having issues passing a value (custID) to the Customer Credit Manager.
I have no issues when I switch up the credit manager entry to customer entry, the value passes and works.
The value I am trying to pass is custID. I know it works, but just does not with the Customer Credit Manager.
Any help would be greatly appreciated.
Maybe it’s custnum not custid
Yeah, I tried CustNum, CustID, and even CustName (I knew that would not work). Here is the field I am trying to put the value in.
Like I said, when I switched it up to the customer entry it works fine.
What happens if you try to debug using the context menu from the custid field on customer entry?
Customer Credit
Customer Entry (this one works)
I noticed, in the Customer Credit, the keyfields in the dataview is empty.
I checked the customer entry, and it passes to the keyfield.
I saw that in the URL too
Resultant URL Context menu when you open customer entry from
https://xxxxx/Kinetic2024_1_Demo/Apps/Erp/Home/#/view/OMMT1110/Erp.UI.CustomerEntry?channelid=416f857b-32f7-4d88-96e2-d26e9445eeef&layerVersion=0&baseAppVersion=0&useBroadcast=1&company=EPIC06&site=MfgSys&pageId=Details&pageChanged=true&KeyFields.CustID=DALTON
Resultant URL from context menu when you open Customer Credit Manager
https://xxxxxx/Kinetic2024_1_Demo/Apps/Erp/Home/#/view/ARGO3008/Erp.UI.CreditManagerEntry?channelid=c6beacc7-8e6b-4ea7-a418-dd5d71153d69&layerVersion=0&baseAppVersion=0&useBroadcast=1&layerNames=NoLandingPage&company=EPIC06&site=MfgSys&pageId=Details&pageChanged=true
Opening Cust Credit manager from the Landing page
https://xxxxxx/Kinetic2024_1_Demo/Apps/Erp/Home/#/view/ARGO3008/Erp.UI.CreditManagerEntry?channelid=c6d6f2b4-0641-4625-9665-b8d9e8910262&layerVersion=0&baseAppVersion=0&company=EPIC06&site=MfgSys&pageId=Details&KeyFields.CustID=DALTON&pageChanged=true
So the question becomes how do we pass the keyfield over
I took the landing page of customer credit manager and added in the context menu as it was missing, in a hope I could replicate the customer entry context menu process…
I think this post will help…
Thanks! The value passes through from my dashboard to the customer credit manager. I set up an event on the customer credit manager, and it works. But when I open the customer credit page from the waffle, it throws an error.
Launch options
Event on customer credit
Error when I open up the customer credit from the waffle
Sorry not following “Waffle”??? Do you mean if you run it normally from the menu?
If that’s the case then perhaps you need to just do the other side of the condition…
Sorry, yeah the normal menu.
Looks more like a dice to me… but I can see where the waffle comes from when I look really hard… :slight_smile:
For sure, it does look more like dice. I dig it
Or a Rubik’s cube for the truly colorblind.
I had to change my expression in my condition, but it works smoothly now. No issues passing the value or opening up credit manager from the dice (main menu :slight_smile: ). Thank you for your help!
