Hi
Please do not merge them. This creates too many items to check. The customers prefers to have them separately.
Hi
@matt.whitman1 Here you go - I did a formal write-up:
https://www.epiusers.help/t/the-stoplight-report-a-summary-of-time-phase-for-all-parts/101977
And welcome to the group!
Yes
Yes
No
Too much clutter combined, and we use the changes to quickly send out suppliers, would require more filtering to clean out new buy suggestions
No opinion
I realize that there is some confusion about question 4⌠if we were to combine them (safe harbor) we would be combining the two APPS into one APP, but two different sections as illustrated below in these mockups⌠so essentially, the two suggestion types are still separate, but within the same application.
NEW PO Suggestions:
CHANGE PO Suggestions:
Ah OK, not how I took that, so itâs a needed clarification.
Regardless, I agree, itâs confusing to our people that there are two screens, and combining them is a step forward.
Response from our Purchasing team:
The crucial question would be âhow will it look?â
Without seeing a layout it would be impossible to say whether this would be a good or bad creation.
Thank you @steveh for the information. re âhow it will lookâ, you can see a preview here: OPINIONS WANTED: New PO Suggestions vs Change PO Suggestions? - #26 by timshuwy
We use change suggestions since our job schedule seems to fluctuate, more now that the supply chain is difficult. Sometimes the job has to be moved because of parts that wont be available until a certain date. Not all of our vendors are able to give us accurate dates. Our inventory is mostly Just in time as well.
Does your purchasing department use New PO Suggestions. Yes - Daily
Does your purchasing department use Change PO Suggestions â Yes Daily
Do you have any security differences between these two apps? No
If these apps were to be combined into one all called âPO Suggestionsâ {EDIT: the combined APP would have two sections⌠one for NEW and one for CHANGE} how would that positively or negatively affect your world? (ie⌠do you see rainbows and butterflies, you are ambivalent, or this idea would enrage you). For the love of God, Donât combine them. It would make it a hot mess.
If we do combine these, would changing the menu optionâs name cause you grief or happiness? Great Sadness. All of our Work Instructionâs and training information would need to change
