Order has been shipped, cannot add. Adding lines to TF Order
I am getting the error
when I run some C# code. I have no idea what is causing this. I am creating the TFOrdHed record just fine, it just fails when it tries to create the lines for the order.
Here is my code where I create these. MessageBox "2" is as far as it gets when trying to create the dtl before the error. It never reaches 3:
 private void CallTransferOrderEntryAdapterGetNewTFOrdHedMethod()
  try
   // Declare and Initialize EpiDataView Variables
     // Declare and create an instance of the Adapter.
   TransferOrderEntryAdapter adapterTransferOrderEntry = new TransferOrderEntryAdapter(this.oTrans);
   adapterTransferOrderEntry.BOConnect();
   // Declare and Initialize Variables
   string tfOrdNum="";
   // Call Adapter method
   //bool test = adapterTransferOrderEntry.GetByID(tfOrdNum);
   bool result = adapterTransferOrderEntry.GetNewTFOrdHed();
   TransferOrderEntryDataSet toeds = adapterTransferOrderEntry.TransferOrderEntryData;
   toeds.TFOrdHed[0].OrderDate      = DateTime.Today;
   toeds.TFOrdHed[0].ToPlant        = cmbToWH.Value.ToString();
   toeds.TFOrdHed[0].ShipViaCode    = "101";
   toeds.TFOrdHed[0].Plant          = cmbFromWH.Value.ToString();
   toeds.TFOrdHed[0].Date01         = DateTime.Today;
   toeds.TFOrdHed[0].Date02         = DateTime.Today;
   toeds.TFOrdHed[0].Shipped         = false;
   //toeds.TFOrdHed[0].EntryPerson    = DcdUserID;
   bool test = adapterTransferOrderEntry.Update();
   TransferOrderEntryDataSet toedsu = adapterTransferOrderEntry.TransferOrderEntryData;
      string TFOrdNum = toeds.TFOrdHed[0].TFOrdNum;
   EpiDataView tfoedv = (EpiDataView)oTrans.EpiDataViews["TFOrdHed"];
    foreach (Infragistics.Win.UltraWinGrid.UltraGridRow row in grdResults.Rows)
            if (Convert.ToBoolean(row.Cells[0].Value))
   CallTransferOrderEntryAdapterGetNewTFOrdDtlMethod(row,TFOrdNum ,tfoedv );
   // Cleanup Adapter Reference
   adapterTransferOrderEntry.Dispose();
  } catch (System.Exception ex)
   ExceptionBox.Show(ex);
 private void CallTransferOrderEntryAdapterGetNewTFOrdDtlMethod(Infragistics.Win.UltraWinGrid.UltraGridRow row, String TFOrdNum,EpiDataView view )
  MessageBox.Show("1");
  try
   MessageBox.Show("2");
   adapterTransferOrderEntry.GetByID(TFOrdNum);
   TransferOrderEntryDataSet datasettfo = adapterTransferOrderEntry.TransferOrderEntryData;
   bool dtl = adapterTransferOrderEntry.GetNewTFOrdDtl();
   TransferOrderEntryDataSet toedsdtl = adapterTransferOrderEntry.TransferOrderEntryData;
   MessageBox.Show("3");
  toedsdtl.TFOrdDtl[0].TFOrdNum    =TFOrdNum;
  toedsdtl.TFOrdDtl[0].OrderFirm         = true;
        toedsdtl.TFOrdDtl[0].CreateOrder       = true;
        toedsdtl.TFOrdDtl[0].RequiredQty       = Convert.ToDecimal(row.Cells[8].Value);
        toedsdtl.TFOrdDtl[0].OurStockQty       = toedsdtl.TFOrdDtl[0].RequiredQty;
        toedsdtl.TFOrdDtl[0].SellingQty        = toedsdtl.TFOrdDtl[0].RequiredQty;
        toedsdtl.TFOrdDtl[0].ThisOrderInvtyQty = toedsdtl.TFOrdDtl[0].RequiredQty;
        toedsdtl.TFOrdDtl[0].Selected          = true;
  toedsdtl.TFOrdDtl[0].PartNum     =(row.Cells[1].Value.ToString());
  toedsdtl.TFOrdDtl[0].SellingQtyUOM  =(row.Cells[3].Value.ToString());
  toedsdtl.TFOrdDtl[0].Shipped         = false;
   bool result = adapterTransferOrderEntry.Update();
   MessageBox.Show("4");
