OT- DNS Errors over Dial UP
thanks Russ & Todd. I got it worked out.
Sent: Monday, March 22, 2004 2:20 PM
Subject: Re: [Vantage] OT- DNS Errors over Dial UP
Lois
Your ISP's DNS could be down. I liked Todd's answers but I don't
think they apply to dial-up. Winsock gets the DNS address when it
initiates the connection. I would call the ISP for advise. If they're
having a problem they should let you know then.
(HTH)
Russ Dover
Subject: [Vantage] OT- DNS Errors over Dial UP
> I connect via dial up to my ISP. I open IE 6.1 and it
> errors out with DNS errors. What can I do to fix this?
> WHy is it erroring out?
> must have already linked your email address to a yahoo id to enable
> access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder
> and Crystal Reports and other 'goodies', please goto:
Yahoo! Groups Links
Two things I've seen do this.
1. No DNS server entry in the network properties. Or the DNS server listed is wrong or not available. Or if I recall correctly there is a setting for searching for a DNS server which should pick the ISP's automatically.
2. IE is trying to use a proxy server when there is none or it is wrong. Or, on a PC that formerly connected via proxy server even if IE has that turned off there may still be a proxy service running. Check install/uninstall programs and see if a proxy program is listed and uninstall it if not needed anymore.
Something to try might be to try to access a site directly by the IP address. For www.msn.com it would be 207.68.171.245. See if you can connect without using a DNS server to resolve the IP address by typing that IP into the address line. At least then you would know the rest of the connection is working or not.
-Todd C.
Sent: Monday, March 22, 2004 12:17 PM
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://rd.yahoo.com/SIG=12cn8srnt/M=268585.4521611.5694062.1261774/D=egroupweb/S=1705007183:HM/EXP=1080065908/A=1950447/R=0/SIG=1245hvqf1/*http://ashnin.com/clk/muryutaitakenattogyo?YH=4521611&yhad=1950447> click here
<http://us.adserver.yahoo.com/l?M=268585.4521611.5694062.1261774/D=egroupweb/S=:HM/A=1950447/rand=229648055>
_____
Yahoo! Groups Links
vantage-unsubscribe@yahoogroups.com <mailto:vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service <http://docs.yahoo.com/info/terms/> .
Lois
(HTH)
Russ Dover
> access. )
