OT - Excel
If you have outlook and have your journal on it will tell you where this
file is.
Sent: Wednesday, August 07, 2002 10:31 AM
To: 'vantage@yahoogroups.com'
Subject: [Vantage] OT - Excel
I've lost a spreadsheet that I spent almost a full day developing. I've
searched in every location (local, network, zip backups, etc.) and using
every method I could think of (title, recent, date modified, etc.) This
workbook had several worksheets within it and my last hope before
starting over is to do a search on a worksheet name within a workbook.
Is this even possible? I'm hoping I saved the file in some bizarre
location using some strange name and can find it using a worksheet name.
Please, someone, make my day!!!
Marty Kuphall
Controller
Ultra Tool & Mfg., Inc.
Ph. 262-703-0455
Fx. 262-703-0468
marty.kuphall@...
Yahoo! Groups Sponsor
<http://rd.yahoo.com/M=225674.2075965.3644786.1829184/D=egroupweb/S=1705
007183:HM/A=1153156/R=0/*http://www.lensexpress.com/tracker/trackclick.a
spx?Page=ACUVUE%202%20Colors&AffUrl=273&AffCode=14> Click here to visit
our exclusive feature of ACUVUE2 Colours at LensExpress.com!
Click here to find your contact lenses!
Marty Kuphall
Controller
Ph. 262-703-0455
Fx. 262-703-0468
marty.kuphall@...
In Excel XP, under tools/options/save tab, you have the option to specify
an autosave feature. Also how often the program saves to this file.
You might get lucky and find your document there.
For example, my setting is c:\documents and settings\username\application
data\microsoft\excel.
Goodluck,
workbook had several worksheets within it and my last hope before starting
over is to do a search on a worksheet name within a workbook. Is this even
possible? I'm hoping I saved the file in some bizarre location using some
Marty,
The only thing I can think of is:
In Excel -
Click On Open
On the tools menu click find
Specify the search criteria - there is an extensive list to choose from.
Then click add to list.
Then search away.
I hope this helps.
Dina
P.S. I am assuming you looked under documents (start - documents) to see what the last documents we have accessed) - Just another thought that might help you.
> Marty Kuphall
> Controller
> Ph. 262-703-0455
> Fx. 262-703-0468
> marty.kuphall@...
> Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must have already linked your email address to a yahoo id to enable access. )
> (1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.
> (2) To search through old msg's goto: http://groups.yahoo.com/group/vantage/messages
> (3) To view links to Vendors that provide Vantage services goto: http://groups.yahoo.com/group/vantage/links
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
Dina M. Hieber
Vamco International, Inc.
555 Epsilon Drive
Pittsburgh, PA 15238
(412) 963-7100 - phone
(412) 963-9511 - fax
www.vamcointernational.com
If you were just working on it, the file should be in Excel's recent file
list no?
Michael
Sent: Wednesday, August 07, 2002 8:31 AM
Marty Kuphall
Controller
Ph. 262-703-0455
Fx. 262-703-0468
marty.kuphall@...
Thanks to those who responded, but no luck. I worked on it late last week and it's not in recent, not in my default location, not anywhere using any of the Excel or W2K
search tools. I even opened up all of the recent files just in case it was under one of those names. In fact, I opened up every Excel file that had a modified date within
the last two weeks. That was fun!
I can't believe I didn't save it while I was working on it or ignored Excel's warning about saving it before I exited Excel, but all evidence suggests that is exactly what
happened.
The last question is do I drink coffee and get started or do I go to the liquor cabinet and.....
Thanks again,
Marty Idiot (formerly Marty Kuphall)
Make sure it's just not hidden. If the file opens but is blank that may be
the problem. Happened to a user here.
Good Luck.
Jim Moore
GD-OTS
Sent: Wednesday, August 07, 2002 11:16 AM
Subject: Re: [Vantage] OT - Excel
of the Excel or W2K
happened.
Thanks again,
Jim,
Do you have any mapped drives on your system. I beat my users about the
head and shoulders for not saving their documents to the network drive.
(Everybody has a secure folder on the server) Maybe it went there. Also,
(just in case you havent tried this) go to START, SEARCH, set your search
parameters to "search for files folders "*.xls" then in the field below
enter a text word or phrase that you KNOW is in your spreadsheet. Then
search EVERYTHING, all your drives and any mapped drives. It might take a
little time but I've found every lost document that wasnt deleted. Another
thought, is it possible you saved it in a format that is NOT .XLS. If so do
the same search as above except without the "*.xls"
Shirley
From: Moore, Jim (Anniston) [mailto:jmoore@...-ots.com]
Sent: Wednesday, August 07, 2002 12:24 PM
Subject: RE: [Vantage] OT - Excel
Good Luck.
Jim Moore
GD-OTS
of the Excel or W2K
happened.
Thanks again,
have
ADVERTISEMENT
Maybe the file extension got changed from XLS to something else? I would do
a search for *all* files modified in the last couple of days and see if
there are any that are the right size to have been your file.
Brian
Marty,
If you know some of the text that would be specific to that file, enter that
in the "Containing Text" box in explorer search. Also - you may have
entered a control character into the name somehow that caused it not to
show. Again, search with "containing text". Good luck.
Gary Polvinale
Sent: Wednesday, August 07, 2002 11:31 AM
Marty Kuphall
Controller
Ph. 262-703-0455
Fx. 262-703-0468
marty.kuphall@...
