OT Lockdown
I'm assuming I need to study up on policies under Win 2003 server active
directory. I didn't know it could do that.
Paul L.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of
dave.miller2@...
Sent: Friday, July 28, 2006 7:37 AM
Subject: Re: [Vantage] OT Lockdown
Paul,
If I understand your question correctly I would recommend using Group
Policies to lock down the Win2K and XP desktops to the user. We use this for
our plant floor workstations. They can only access the data collection short
cut on the desktop and that's it...everything else is disabled.
Dave Miller
Prince Industries, Inc.
-------------- Original message --------------
We are starting the process of evaluating software to limit access to
Windows 2000 Pro and Windows XP Pro desktops. It's getting to the point we
must only allow users access to certain programs, etc. We have never had
to
do this before and it's hard to establish a market leader in this area.
Any
information would be helpful at this point.
Paul Lipham
I.T. Manager
Alabama Specialty Products, Inc.
paull@... <mailto:paull@...>
256-358-5200
I am not sure if I have ever seen an answer to this but is it possible to run an "export" in RB directly from a Vantage menu? I have cheated a few times and printed to "file" but I now have one where the formatting is super critical and only Export will handle it correctly. I would rathter the user not have to go into "raw" RB to select the Export option under Print. The file name will be constant but the date range in the filter will need to be changed each week (dumping payroll hours to Paychex).
Or...is there any way with a command line or .p routine to activate RB and do the export while also giving the filter change window?
Todd Caughey
Harvey Vogel Mfg. Co.
You can create a .P or .W application that prompts the user for the date range and execute RB to dump to a file fairly easy.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of Todd Caughey
Sent: Thursday, July 27, 2006 10:20 AM
To: Vantage@yahoogroups.com
Subject: [Vantage] RB Export from Vantage Menu
Todd Caughey
Todd,
I can throw something together for you. Should only take 15 min or
so.
I'll need to know all the entries for the report filter (a screen
snapshot will do), along with the PRL and path, and the report name.
Glad to help,
Lonnie
window?
> Thanks,
> Todd Caughey
That would be great. I will send off-list. All I need is a starting point or example of the code.
-Todd C.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com]On Behalf Of lonniedrew
Sent: Thursday, July 27, 2006 11:31 AM
Subject: [Vantage] Re: RB Export from Vantage Menu
Todd,
so.
Glad to help,
Lonnie
--- In vantage@yahoogroups <mailto:vantage%40yahoogroups.com> .com, "Todd Caughey" <caugheyt@...> wrote:
window?
> Thanks,
> Todd Caughey
must only allow users access to certain programs, etc. We have never had to
do this before and it's hard to establish a market leader in this area. Any
Paul Lipham
I.T. Manager
256-358-5200
Paul,
I use Fortress 101 by Fortress Grand Corporation.
http://www.fortresgrand.com/
I have had very good luck with the product and run it on every PC on the
shop floor.
Patrick Winter
Of Paul Lipham
Sent: Thursday, July 27, 2006 1:27 PM
Subject: [Vantage] OT Lockdown
we
to
Any
Paul Lipham
I.T. Manager
paull@... <mailto:paull%40alspi.com> <mailto:paull@...
<mailto:paull%40alspi.com> >
256-358-5200
This e-mail and any attachments may contain confidential and
privileged information. If you are not the intended recipient,
please notify the sender immediately by return e-mail, delete this
e-mail and destroy any copies. Any dissemination or use of this
information by a person other than the intended recipient is
unauthorized and may be illegal.
Hi Paul,
Just in case you didn't know, you have the ability to do this for free
if you have a Window 2000 or 2003 domain and these computers connect to
that domain.
It requires a bit of work to plan and test but you can use Group
Policies.
MS has a pretty cool console to help manage GPOs. (this console can only
run from XP or 2003 but I believe it manages a 2000 and 2003 domain.)
http://www.microsoft.com/windowsserver2003/gpmc/default.mspx
On top of that MS has a package called "Group Policy Common Scenarios"
that is designed to work with the above console to load predefined GPOs
for common scenarios.
These templates can be tweak to get just them just right for you.
https://www.microsoft.com/downloads/details.aspx?familyid=354b9f45-8aa6-
4775-9208-c681a7043292&displaylang=en
I use GPOs here and I will be modifying one of the templates to control
our MES computers.
Again, it does require more work on your part and if you haven't used
GPOs before there will be a learning curve but the price is right! :-)
I think all the third party products do is make interacting with GPOs
and Local Policies easier.
Joe Rojas
IT Manager
TNCO, Inc.
781-447-6661 x7506
jrojas@...
Of Paul Lipham
Sent: Thursday, July 27, 2006 2:27 PM
we
to
Any
Paul Lipham
I.T. Manager
256-358-5200
Paul,
If I understand your question correctly I would recommend using Group Policies to lock down the Win2K and XP desktops to the user. We use this for our plant floor workstations. They can only access the data collection short cut on the desktop and that's it...everything else is disabled.
Dave Miller
Paul Lipham
I.T. Manager
256-358-5200
Hi Michael,
I am not familiar with the .p .w file types and how to create them.
I would also like to know if it is possible to have these file types
Run from the plant floor module?
Thanks in advance,
John Mansfield
General Sheet Metal
