OT: Preventing Users from Changing Settings
Windows XP Pro has a built in GP Tool for Workgroup computers
(gpedit.mmc), this page has some helpful information on how to use this
tool on the station: http://www.theeldergeek.com/gp04.htm
But using the policy mmc snap-in, you can edit the appropriate settings
of the user, just as you would in a Domain env. The difference is that
the settings will be applied only to that one station, but by creating a
template, you may save that template and copy it to another workstation
as you please. Exploring the MS Knowlegde Base will point you to helpful
policy settings that can be imported to the station and expand
functionality.
The Policy MMC Snap-in will allow you to edit the local computer policy
by default, if you ever move to a AD enviornment, by joining the
computer to the AD, the local settings that have been changed on a
domain level will be overridden, although, the settings that do not
overlap and have been changed locally, will stay in effect, so it is
strongly suggested, that before you make any changes to the settings,
that you create a backup copy of the default template, so that you may
return to the initial settings at any time.
Thomas Wojewoda
IS Manager
Principal Manufacturing Corp.
2800 South 19th Ave.
Broadview, IL 60155
http://www.principalmfg.com
ph. (708) 865 7500
fx. (708) 865 7632
cl. (708) 259 4864
_____
Of Ben Belzer
Sent: Monday, April 17, 2006 12:11 PM
Subject: [Vantage] OT: Preventing Users from Changing Settings
Does anyone know a good program for preventing my shop floor users from
deleting icons, moving the taskbar, accessing the internet, moving icons
around on the desktop, etc.?
I remember seeing this in student computer labs. They would restrict
everything but the few programs you actually needed to use.
Thanks!
Ben Belzer
IT Manager
TCI Precision Metals
800.234.5613.W
310.323.1255.F
bbelzer@... <mailto:bbelzer@...>
www.tciprecision.com <http://www.tciprecision.com/>
have
and
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring
+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=P
da+database+software&w5=Database+management+software&w6=Database+marketi
ng+s
oftware&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA> software
Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+sof
twar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database+m
arke
ting+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
actu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&
w4=Pda+database+software&w5=Database+management+software&w6=Database+mar
keti
ng+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A> mortgage software
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w
4=Pd
a+database+software&w5=Database+management+software&w6=Database+marketin
g+so
ftware&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg> database software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
ufac
twar
arke
ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management
software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
fact
uring+software&w2=Membership+database+software&w3=Database+mortgage+soft
ware
&w4=Pda+database+software&w5=Database+management+software&w6=Database+ma
rket
ing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw> marketing software
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage
<http://groups.yahoo.com/group/vantage> "
on the web.
* Your use of Yahoo! Groups is subject to the Yahoo!
<http://docs.yahoo.com/info/terms/> Terms of Service.
_____
Yahoo! Groups Links
Thanks!
Ben Belzer
IT Manager
800.234.5613.W
310.323.1255.F
Ben,
If all your shop floor machines are running W2K or later and you are
running W2K server or later with active directory you can enable
mandatory profiles that will lock down the desktop and prevent the users
from making any changes.
Chris
_____
Of Ben Belzer
Sent: Monday, April 17, 2006 9:11 AM
Thanks!
Ben Belzer
IT Manager
800.234.5613.W
310.323.1255.F
A lot of it can be done through windows system policy settings. If you are
using a domain-based network (as opposed to a work-group based network) this
is a lot easier, however. I assume you are on a workgroup network, since
you are asking the question.
For windows XP / 2000, click Start, Run and type "gpedit.msc" - this will
load the global system policies editor. Note: Any changes you make here are
system wide, meaning they affect all users for that computer. So if you
lock things down really tight, you could potentially lock yourself out as
well. The best thing to do is not disable the command prompt, and put a
shortcut on the administrators desktop to the command prompt. From there
you can open the gpedit.msc snap-in, and disable restrictions if you need to
make changes.
The place you want to be modifying is under "User Configuration",
"Administrative Templates". From there it is pretty self-explanatory. With
some time you can get the system completely locked down.
Tom
IT Dept.
<mailto:it@...> it@...
570-476-9700 ext.29
_____
Ben Belzer
Thanks!
Ben Belzer
IT Manager
800.234.5613.W
310.323.1255.F
SPONSORED LINKS
Manufacturing
<http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufacturing
+software&w2=Membership+database+software&w3=Database+mortgage+software&w4=P
da+database+software&w5=Database+management+software&w6=Database+marketing+s
Membership
<http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Manufac
turing+software&w2=Membership+database+software&w3=Database+mortgage+softwar
e&w4=Pda+database+software&w5=Database+management+software&w6=Database+marke
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+software&
w4=Pda+database+software&w5=Database+management+software&w6=Database+marketi
Pda
<http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufacturing+
software&w2=Membership+database+software&w3=Database+mortgage+software&w4=Pd
a+database+software&w5=Database+management+software&w6=Database+marketing+so
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Manufac
ting+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw> management software
Database
<http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manufact
uring+software&w2=Membership+database+software&w3=Database+mortgage+software
&w4=Pda+database+software&w5=Database+management+software&w6=Database+market
_____
YAHOO! GROUPS LINKS
* Visit your group "vantage <http://groups.yahoo.com/group/vantage> "
on the web.
_____
