Out Of Memory Error
No code on these particular dashboards. I am the only one getting the message, but then again I am the only one doing heavy customizations as well. I only seem to get the error when testing configurator code, which there is a lot of. Thanks for all your help and the "New Trick" :D Guess I will call support, I know they did a lot of changes to the configurator this update.
Brenda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Dan Sirow
Sent: Wednesday, June 26, 2013 2:30 PM
Subject: [Vantage] Re: Out Of Memory Error
The 1st, 4th and 5th are normal.
I think ( but don't quote me), as long as you have no Visual Basic code or c# code in those screens, it is a bug and you need to work with support to get an SCR written.
A few times, I actually figured out how to reproduce a memory leak, got an SCR written and they fixed the leak.
Do you get an Out of Memory Error if you do not use those dashboards? That is the real question to determine if the leak is what is causing your error.
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@...<mailto:brenda@...>> wrote:
> Awesome, I have 5
> Epicor.Mfg.MenuForm Live 54444047
> Epicor.Mfg.UI.App.Hum_Sales_Tracker.MainController Live 32547908
> Epicor.Mfg.UI.App.HM_Package_Credit.MainController Live 24495719
> Epicor.Mfg.UI.App.SysMonitorEntry.Transaction Live 19134881
> Epicor.Mfg.UI.App. SysMonitorEntry.SysMonitorForm Hidden 5938035
> I re-opened Epicor and hit Refresh I got these. The 2nd and 3rd are Dashboards that I don't use that often, but others use constantly. So why would I be the only one getting the error? (Besides the fact I am obviously a resource hog)
> So now I know I have a leak, what could be causing it and how do I fix it? I know I re-compiled the Package_Credit Dashboard because it is updatable and ALL of those had to be re-compiled after the upgrade. The Sales_Tracker is just a pretty graph that shows sales by month.
> Brenda
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Dan Sirow
> Sent: Wednesday, June 26, 2013 11:06 AM
> With only the menu open, you should see just 3 lines, if you see more there is a memory leak
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, Anthony Gercar <agercar@<mailto:agercar@>> wrote:
> > Put -MEMORY at the end of target. Looks like this.
> > "C:\Program Files\Epicor Software\Epicor905\Client\MfgSys.exe" -MEMORY
> > Then run as administrator. You need to click refresh when you load or close screens.
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of brenda mohr
> > Sent: Wednesday, June 26, 2013 10:52 AM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > Subject: RE: [Vantage] Re: Out Of Memory Error
> > I can get this off EpicWeb?
> > Brenda
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Dan Sirow
> > Sent: Wednesday, June 26, 2013 9:41 AM
> > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > Have you tried the Memory Leak Tester? I have found customizations that start leaking after an upgrade and the customization need to be redone from scratch? Or, there may be a leak in the a standard 702 screen.
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@<mailto:brenda@%3cmailto:brenda@>>> wrote:
> > > I tend to get it when I am testing my configurator This did not happen prior to upgrade and I always have a zillion things open, but I am a busy girl. My laptop REFUSES to run 64bit. I have tried all the tricks except starting over.
> > > Brenda
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of ralmon64
> > > Sent: Tuesday, June 25, 2013 8:14 AM
> > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > Is there a particular program you are in when this happens. I noticed that if i have the AP or AR Invoice Entry program open, I will get this error, especially if I have a lot of Epicor windows open. Don't have the problem with any other programs though.
> > > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > > > Steve,
> > > > Thanks for the response.
> > > > Sounds like I need to F-Disk my laptop (~Evil Laugh~). Among other things, the only way to get my laptop to run Epicor is in "XP Compatibility Mode". AND for some reason Crystal 64 hates us and will not run ~ sadness.
> > > > Brenda
> > > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Steve
> > > > Sent: Monday, June 24, 2013 10:41 AM
> > > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > > Subject: RE: [Vantage] Out Of Memory Error
> > > > You can run the client in 64 bit mode to get around these errors. Just keep
> > > > in mind you need to install the 64 bit Crystal runtime and may have to
> > > > configure 64 bit odbc if you are running Crystal reports out of menu.
> > > > Steve
> > > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of
> > > > brenda mohr
> > > > Sent: Monday, June 24, 2013 8:44 AM
> > > > To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>
> > > > Subject: [Vantage] Out Of Memory Error
> > > > We upgraded to 702 last week and since then, I have been getting the
> > > > following error sporadically while testing inputs in the configurator.
> > > > Sometimes I can continue after clicking OK, sometimes I cant. Any ideas?
> > > > Error Detail
> > > > Exception of type 'System.OutOfMemoryException' was thrown.
> > > > Stack Trace
> > > > at System.String.GetStringForStringBuilder(String value, Int32 startIndex,
> > > > Int32 length, Int32 capacity)
> > > > at System.Text.StringBuilder.GetNewString(String currentString, Int32
> > > > requiredLength)
> > > > at System.Text.StringBuilder.Append(Char[] value, Int32 startIndex, Int32
> > > > charCount)
> > > > at System.Text.StringBuilder.AppendFormat(IFormatProvider provider, String
> > > > format, Object[] args)
> > > > at Epicor.Mfg.Diagnostics.DataTracer.DumpTableChanges(StringBuilder sb,
> > > > DataTable table, DataTable origTable)
> > > > at Epicor.Mfg.Diagnostics.DataTracer.WritePacket(TracePacket packet)
> > > > at Epicor.Mfg.Proxy.ConfigurationImpl.ApplyLeave(String parentMfgCompID,
> > > > String partNum, String revisionNum, Int32 pageNum, String inputName, String
> > > > testMode, ConfigurationValueDataSet ds, Int32 mtlSeq, String ruleTag,
> > > > GeneratedConfigurationDataSet ds1)
> > > > at Epicor.Mfg.UI.Adapters.ConfigurationAdapter.ApplyLeave(String
> > > > parentMfgCompID, String partNum, String revisionNum, Int32 pageNum, String
> > > > inputName, String testMode, ConfigurationValueDataSet ds, Int32 mtlSeq,
> > > > String ruleTag, GeneratedConfigurationDataSet ds1)
> > > > Brenda
> > > > [Non-text portions of this message have been removed]
We upgraded to 702 last week and since then, I have been getting the following error sporadically while testing inputs in the configurator. Sometimes I can continue after clicking OK, sometimes I cant. Any ideas?
Error Detail
Stack Trace
at System.String.GetStringForStringBuilder(String value, Int32 startIndex, Int32 length, Int32 capacity)
at System.Text.StringBuilder.GetNewString(String currentString, Int32 requiredLength)
at System.Text.StringBuilder.Append(Char[] value, Int32 startIndex, Int32 charCount)
at System.Text.StringBuilder.AppendFormat(IFormatProvider provider, String format, Object[] args)
at Epicor.Mfg.Diagnostics.DataTracer.DumpTableChanges(StringBuilder sb, DataTable table, DataTable origTable)
at Epicor.Mfg.Proxy.ConfigurationImpl.ApplyLeave(String parentMfgCompID, String partNum, String revisionNum, Int32 pageNum, String inputName, String testMode, ConfigurationValueDataSet ds, Int32 mtlSeq, String ruleTag, GeneratedConfigurationDataSet ds1)
at Epicor.Mfg.UI.Adapters.ConfigurationAdapter.ApplyLeave(String parentMfgCompID, String partNum, String revisionNum, Int32 pageNum, String inputName, String testMode, ConfigurationValueDataSet ds, Int32 mtlSeq, String ruleTag, GeneratedConfigurationDataSet ds1)
Brenda
Steve
brenda mohr
Error Detail
Stack Trace
requiredLength)
charCount)
Brenda
Steve,
Brenda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Steve
Steve
brenda mohr
Error Detail
Stack Trace
requiredLength)
charCount)
Brenda
How do you set your client to run Epicor in x64 mode?
Ross
Change the shortcut to use mfgsys64.exe instead of mfgsys.exe.
rossmc1988
Sent: Tuesday, June 25, 2013 3:26 AM
Ross
--- In vantage@yahoogroups.com, brenda mohr <brenda@...> wrote:
> Steve,
> Brenda
> Steve
> brenda mohr
> Error Detail
> Stack Trace
> requiredLength)
> charCount)
> Brenda
Brenda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of ralmon64
> Steve,
> Brenda
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Steve
> Steve
> brenda mohr
> Error Detail
> Stack Trace
> requiredLength)
> charCount)
> Brenda
> Brenda
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > Steve,
> > Brenda
> > Steve
> > brenda mohr
> > Error Detail
> > Stack Trace
> > requiredLength)
> > charCount)
> > Brenda
Brenda
> Brenda
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of ralmon64
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > Steve,
> > Brenda
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Steve
> > Steve
> > brenda mohr
> > Error Detail
> > Stack Trace
> > requiredLength)
> > charCount)
> > Brenda
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of brenda mohr
Brenda
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@...<mailto:brenda@...<mailto:brenda@...%3cmailto:brenda@...>>> wrote:
> Brenda
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of ralmon64
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > Steve,
> > Brenda
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Steve
> > Steve
> > brenda mohr
> > Error Detail
> > Stack Trace
> > requiredLength)
> > charCount)
> > Brenda
> Brenda
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@<mailto:brenda@%3cmailto:brenda@>>> wrote:
> > Brenda
> > > Steve,
> > > Brenda
> > > Steve
> > > brenda mohr
> > > Error Detail
> > > Stack Trace
> > > requiredLength)
> > > charCount)
> > > Brenda
Awesome, I have 5
Brenda
--- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Anthony Gercar <agercar@...<mailto:agercar@...>> wrote:
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of brenda mohr
> Brenda
> From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Dan Sirow
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@<mailto:brenda@%3cmailto:brenda@>>> wrote:
> > Brenda
> > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of ralmon64
> > --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>, brenda mohr <brenda@<mailto:brenda@>> wrote:
> > > Steve,
> > > Brenda
> > > From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com> [mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com><mailto:vantage%40yahoogroups.com>] On Behalf Of Steve
> > > Steve
> > > brenda mohr
> > > Error Detail
> > > Stack Trace
> > > requiredLength)
> > > charCount)
> > > Brenda
> Awesome, I have 5
> Brenda
> --- In vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>, Anthony Gercar <agercar@<mailto:agercar@>> wrote:
> > Brenda
> > > Brenda
> > > > Steve,
> > > > Brenda
> > > > Steve
> > > > brenda mohr
> > > > Error Detail
> > > > Stack Trace
> > > > requiredLength)
> > > > charCount)
> > > > Brenda
I tried adding the -memory to the end of my target in the shortcut and I get invalid path
> Awesome, I have 5
> Brenda
> > Brenda
> > > Brenda
> > > > Steve,
> > > > Brenda
> > > > Steve
> > > > brenda mohr
> > > > Error Detail
> > > > Stack Trace
> > > > requiredLength)
> > > > charCount)
> > > > Brenda
