We have a similar problem using AND with 2 wildcards.
For example we have parts with the description of 'Outer Formed Panels' of
various sizes/colours etc.
In previous versions of E9 (9.04 & 9.05.606A) we were able to search using
OUT* FORM* which returned a load of records, however since moving to
9.05.700B2 this no longer works. This is definitely the case as we still
have 9.05.606A on one of our test servers.
Any suggestions?
The main problem is because users expect results with 2 wildcards, if the
search returns nothing they assume there are no records, when it is the
search that is no longer working as it did.
Darryn
Mark Wonsil
Sent: 12 September 2012 03:14
Subject: Re: [Vantage] Re: Part description search
Try putting * in there too.
On Sep 11, 2012, at 9:20 PM, Neil Buckman
<nbuckman@...>
wrote:
Yes, we get nothing if we enter after the first line and put nothing on the
second.
And if a comma is in the middle of the text we get an error.
- Neil Buckman
Ned
Sent: Wednesday, 12 September 2012 10:48 AM
Subject: RE: [Vantage] Re: Part description search
Also be warned, you will likely get errors if you hit return and then put
nothing on the second line.
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com> [mailto:
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Neil
Buckman
Sent: Tuesday, September 11, 2012 7:51 PM
Thanks Mark,
I have it working now, but I was perplexed by the AND OR options.
I enter "alum 6500" on one line and I get all the aluminium that has 6500 in
the description. But if I put the same thing on 2 lines finds nothing.
It seems to need at least two words on the second line to work. So "alum
6500" on line one and "post red" on line two give correct OR results, but
"alum 6500" on line one and "post" on line two finds nothing. But reverse
the order ("post" on line one and "alum 6500" on line two) and it works.
Thanks for the tip. It is most useful.
- Neil Buckman
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>] On Behalf Of Mark
Wonsil
Sent: Tuesday, 11 September 2012 12:30 PM
BTW, once you get your indexing set up, the command will AND on one one and
OR each line so:
alum nut
alum bolt
Will find all of your aluminum nuts and bolts.
Mark W.
On Sep 10, 2012, at 7:14 PM, Neil Buckman
<nbuckman@...<mailto:
nbuckman%40gibsonshopfitters.com.au><mailto:
nbuckman@...<mailto:nbuckman%40gibsonshopfitters.com.au
Thanks Chris,
I will follow this up.
Neil Buckman
Information Technology
[Description: Gibson Shopfitters]
DH Gibson Pty Ltd | 205-231 Fairfield Rd | YENNORA NSW 2161 Office 8724 4600
| Direct 8724 4618 | Fax 8724 4604 | Mobile 0413 125 994
ailto:nbuckman@...<mailto:
nbuckman%40gibsonshopfitters.com.au>%3cmailto:nbuckman@gibsonshopfitters.
com.au>>
| www.gibsonshopfitters.com.au<http://www.gibsonshopfitters.com.au>
<http://www.gibsonshopfitters.com.au/>
From: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:
vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>>
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>]<mailto:
[mailto:vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com>]> On
Behalf Of
redrhyno13
Sent: Tuesday, 11 September 2012 5:24 AM
To: vantage@yahoogroups.com<mailto:vantage%40yahoogroups.com><mailto:
Subject: [Vantage] Re: Part description search
In 905.700b2 I had to run a couple of sql scripts furnished by tech support
to get the where part contains searches to work.
Chris Wineinger
Interior Systems Inc.
--- In
vantage%40yahoogroups.com<mailto:vantage@yaho
ogroups.com%3cmailto:vantage%40yahoogroups.com>>, "nbuckman@
...<mailto:nbuckman@...><mailto:nbuckman@%0b...%3cmailto:nbuckman@...%3e>"
<nbuckman@...<mailto:nbuckman@...<mailto:nbuckman@...%3cmailto:nbuckman@
...<mailto:nbuckman@...%3cmailto:nbuckman@...%3cmailto:nbuckman@
...%3cmailto:nbuckman@...>>
invite entry of a portion of a description to filter search results.
brilliantly.
use of the person to whom they are addressed. If you are not the intended
recipient please advise the sender by return e-mail and delete the message
and any attachments. Any use, interference with, disclosure or copying of
this message or any attachments is unauthorised and prohibited.
The sender does not warrant that the information is free of a virus or any
other defect or error, and any views expressed herein, unless specifically
indicated otherwise, are those of the individual sender.
The DH Gibson Group of Companies - http://www.gibsonshopfitters.com.au
P Please consider our shared environment before printing this communication.
http://groups.yahoo.com/group/vantage/files/.<
http://groups.yahoo.com/group/vantage/files/>
Individual Email | Traditional
http://groups.yahoo.com/group/vantage/join
(Yahoo! ID required)
vantage-digest@yahoogroups.com<mailto:vantage-digest%40yahoogroups.com
vantage-fullfeatured@yahoogroups.com<mailto:
vantage-fullfeatured%40yahoogroups.com><mailto:
.com>
vantage-unsubscribe@yahoogroups.com<mailto:
vantage-unsubscribe%40yahoogroups.com><mailto:
vantage-unsubscribe@yahoogroups.c<mailto:vantage-unsubscribe%40yahoogroups.c
http://docs.yahoo.com/info/terms/
Any suggestions?
Darryn
Mark Wonsil
<nbuckman@...>
second.
- Neil Buckman
Ned
Buckman
Thanks Mark,
- Neil Buckman
Wonsil
OR each line so:
alum nut
alum bolt
Mark W.
>>wrote:
Thanks Chris,
Neil Buckman
><mailto:nbuckman@...<mailto:nbuckman%40gibsonshopfitters.com.au><m
com.au>>
Behalf Of
redrhyno13
Chris Wineinger
--- In
>> wrote:search screen headed "Where part description contains..." that seems to
> In Epicor 9.05.700C there is a Part Description box in the basic part
>engineering section of the Engineering Workbench as similar feature works
> Does anyone know how this works? I can get nothing from it at all. In
> the
brilliantly.
>Notice:This e-mail and any attachments are confidential and are only for the
> - Neil
><mailto:vantage-digest@yahoogroups.com<mailto:vantage-digest%40yahoogroups.com>>
.com>
>om>
