Part Inspection Required
I am trying to write a dashboard if inspection required is set on a part. seems easy enough, there is a drop-down to set the if inspection is required. Yay!
This field is bound to Part.RcvInspectionReqPart. I set that to part 1099-2-0 but when I look in the database this field is a 0.
:frowning_with_open_mouth:
How do I tell when inspection required is set?
Are you using the partplant table?
Try this field, PartPlant_RcvInspectionReqPart
Yay, its set there. You would think that if it shows bound to a field it would update that field.
Not exactly the same, but I know what you mean:
(Wow that is ugly as a preview. It’s a nice chart if you go to the post.)
Anyone know the hierarchy for this?
Here is what I have so far:
Vendor->Local Overrides (PO, etc) → PartPlant.RcvInspectionReqPart(nvarchar(1))->Part.RcvInspectionReqPart(nvarchar(1))->PartClass.RcvInspectionReq(bit)
So basically the partPlant.RcvInspectionReq and Part.RcvInspectionReq are both dead fields now based on my understanding.
Below is what i’m thinking it is but not 100% sure without testing.
1. PO/Receipt Status 2. Vendor QA? 3. PartPlant.Rcv…Part 4. Part.Rcv…Part 5. PartClass.RcvInsp Expected Outcome System Rule Validated / Hierarchy Behavior
Force True False N N False PUR-INS Manual Escalation: User manually forced inspection on the line, overriding favorable master setup records.
Locked True True Y Y True PUR-INS Unified Agreement: Vendor and all underlying inventory tiers demand QA inspection.
Locked True True N N False PUR-INS Vendor Dominance: Top-tier vendor flag locks the transaction into inspection, completely ignoring part/site exceptions.
Locked True False Y Y True PUR-INS Site & Global Alignment: Local site and global master record rules perfectly match.
Locked True False Y N False PUR-INS Local Site Mandate: Local facility Y stops evaluation and overrides a global master part set to N.
Locked True False Y "" False PUR-INS Local Site Mandate: Local facility Y forces inspection when the global master part is unconfigured ("").
Available (Blank) False N Y True PUR-STK Site Exemption: Local facility N terminates evaluation early, shielding this warehouse from global part and class constraints.
Available (Blank) False N "" True PUR-STK Site Exemption: Local facility N actively intercepts and overrides baseline PartClass rules.
Available (Blank) False N N False PUR-STK Unified Exemption: Every single record explicitly dictates that inspection is not required.
Locked True False "" Y True PUR-INS Global Part Mandate: Site is pass-through (""), so evaluation falls back to global Part Y which aligns with Class.
Locked True False "" Y False PUR-INS Global Part Mandate: Site is pass-through (""), so evaluation falls back to global Part Y which overrides Class False.
Available (Blank) False "" N True PUR-STK Global Exemption: Site is pass-through (""), so global Part N intercepts evaluation and breaks baseline Class rules.
Available (Blank) False "" N False PUR-STK Global Exemption: Site is pass-through (""), so global Part N aligns with standard baseline Class behavior.
Locked True False "" "" True PUR-INS Class Mandate: Both site and part are pass-through rows; bottom-tier baseline PartClass configuration wins.
Available (Blank) False "" "" False PUR-STK Standard Flow: Total absence of routing overrides ensures parts flow smoothly straight onto the warehouse floor.
Did anyone ever test any of this to verify/validate?
