Part Master Application Error
Thanks for all the help, I was able to fix the issue by removing the adaptor and saving it.
Sent: Wednesday, March 21, 2012 10:17 AM
Subject: [Vantage] Re: Part Master Application Error
Â
I wonder if a control was added and then deleted?
I often get orphans on a form. I've been getting rid of them a couple of ways.
In customization mode, I use the custom xml editor, custom controls grid. There I can remove the values for orphans too.
In customization maintenance I use the verify action to list error and warnings. I am able to delete some of these.
--- In vantage@yahoogroups.com, John Driggers <waffqle@...> wrote:
> I don't see anything that jumps out as wrong. Are you sure that name
> matches your control?
> On Wed, Mar 21, 2012 at 10:01 AM, Lori Gustafson <lori_gus@...> wrote:
> > Here is the code
> > '// Custom VB.NET code for PartForm
> > '// Created: 12/9/2005 11:35:31 AM
> > Imports System
> > Imports System.Data
> > Imports System.Diagnostics
> > Imports System.Windows.Forms
> > Imports System.ComponentModel
> > Imports Microsoft.VisualBasic
> > Imports Epicor.Mfg.UI
> > Imports Epicor.Mfg.UI.FrameWork
> > Imports Epicor.Mfg.UI.ExtendedProps
> > Imports Epicor.Mfg.UI.FormFunctions
> > Imports Epicor.Mfg.UI.Customization
> > Imports Epicor.Mfg.UI.Adapters
> > Imports Epicor.Mfg.UI.Searches
> > Module Script
> > '// ** Wizard Insert Location **
> > '// Begin Wizard Added Module Level Variables **
> > '// End Wizard Added Module Level Variables **
> > '// Add Custom Module Level Variables Here **
> > Sub InitializeCustomCode()
> > '// ** Wizard Insert Location - Do not delete 'Begin/End Custom
> > Method Calls' lines **
> > '// Begin Wizard Added Variable Intialization
> > '// End Wizard Added Variable Intialization
> > '// Begin Custom Method Calls
> > '// End Custom Method Calls
> > End Sub
> > Sub DestroyCustomCode()
> > '// Begin Custom Code Disposal
> > '// End Custom Code Disposal
> > End Sub
> > Private Sub PartForm_Load(ByVal sender As object, ByVal args As
> > EventArgs) Handles PartForm.Load
> > '// Add Event Handler Code
> > LoadUDCombos()
> > End Sub
> > Private Sub LoadUDCombos()
> > Dim recSelected As Boolean
> > '// Load UD02 Combo
> > Dim dsUD01 As DataSet =
> > Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans,
> > "UD01Adapter", recSelected, False, "")
> > If recSelected Then
> > ucbEpiCustom1.ValueMember = "Key1"
> > ucbEpiCustom1.DataSource = dsUD01
> > ucbEpiCustom1.DisplayMember = "Character01"
> > Dim fields As String() = New String() { "Character01" }
> > ucbEpiCustom1.SetColumnFilter(fields)
> > End If
> > End Sub
> > End Module
> > From: John Driggers <waffqle@...>
> > Sent: Wednesday, March 21, 2012 8:27 AM
> > Subject: Re: [Vantage] Part Master Application Error
> > Did you change the name of the combo box?
> > It looks like your code is trying to reference a control that doesn't exist
> > in the last few lines.
> > The first few could be any number of things. If the code isn't terribly
> > long, post it and we can probably help more.
> > On Wed, Mar 21, 2012 at 9:13 AM, Lori Gustafson <lori_gus@...>
> > wrote:
> > > Does anyone know what this error means or how to correct it? We built a
> > > table using UD01 and added an ultra combo box to the Part Master that
> > uses
> > > a retriever to pull in the information in this table and it worked fine
> > > until recently and now we are getting this error message when we open up
> > > the Part Master.
> > > The following application error was encountered:
> > > --------compile errors------------
> > > Error: BC30183 - line 69 (90) - Keyword is not valid as an identifier.
> > > Error: BC30035 - line 140 (161) - Syntax error.
> > > Error: BC30035 - line 214 (235) - Syntax error.
> > > Error: BC30451 - line 72 (290) - Name 'ucbEpiCustom1' is not declared.
> > > Error: BC30451 - line 73 (291) - Name 'ucbEpiCustom1' is not declared.
> > > Error: BC30451 - line 74 (292) - Name 'ucbEpiCustom1' is not declared.
> > > Error: BC30451 - line 76 (294) - Name 'ucbEpiCustom1' is not declared.
> > > ** Compile Failed. **
> > *John Driggers*
> > *High End Dev, System Design, Profit Drinking*
> > **:: 904.404.9233*
> > *:: waffqle@...*
> > *:: NO FAXES*
> > Useful links for the Yahoo!Groups Vantage Board are: ( Note: You must
> > have already linked your email address to a yahoo id to enable access. )
> > (1) To access the Files Section of our Yahoo!Group for Report Builder and
> > Crystal Reports and other 'goodies', please goto:
> > http://groups.yahoo.com/group/vantage/files/.
> > http://groups.yahoo.com/group/vantage/messages
> > (3) To view links to Vendors that provide Vantage services goto:
> > http://groups.yahoo.com/group/vantage/linksYahoo! Groups Links
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
Does anyone know what this error means or how to correct it? We built a table using UD01 and added an ultra combo box to the Part Master that uses a retriever to pull in the information in this table and it worked fine until recently and now we are getting this error message when we open up the Part Master.
Â
Â
Â
> the Part Master.
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
Here is the code
Â
Â
Imports System
Imports System.Data
Â
Module Script
Â
       '// ** Wizard Insert Location - Do not delete 'Begin/End Custom Method Calls' lines **
   End Sub
Â
   End Sub
Â
   Private Sub PartForm_Load(ByVal sender As object, ByVal args As EventArgs) Handles PartForm.Load
       LoadUDCombos()
   End Sub
       Â
      Â
       '// Load UD02 Combo
       Dim dsUD01 As DataSet = Epicor.Mfg.UI.FormFunctions.SearchFunctions.listLookup(oTrans, "UD01Adapter", recSelected, False, "")
       If recSelected Then
       End If
     Â
   End Sub
End Module
> the Part Master.
>Â Error: BC30183 - line 69 (90) - Keyword is not valid as an identifier.
>Â Error: BC30035 - line 140 (161) - Syntax error.
>Â Error: BC30035 - line 214 (235) - Syntax error.
>Â Error: BC30451 - line 72 (290) - Name 'ucbEpiCustom1' is not declared.
>Â Error: BC30451 - line 73 (291) - Name 'ucbEpiCustom1' is not declared.
>Â Error: BC30451 - line 74 (292) - Name 'ucbEpiCustom1' is not declared.
>Â Error: BC30451 - line 76 (294) - Name 'ucbEpiCustom1' is not declared.
>Â ** Compile Failed. **
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
Useful links for the Yahoo!Groups Vantage Board are: ( Note:Â You must have already linked your email address to a yahoo id to enable access. )
(1) To access the Files Section of our Yahoo!Group for Report Builder and Crystal Reports and other 'goodies', please goto: http://groups.yahoo.com/group/vantage/files/.%c2%a0
> Here is the code
> Imports System
> Imports System.Data
> Module Script
> End Sub
> End Sub
> LoadUDCombos()
> End Sub
> '// Load UD02 Combo
> If recSelected Then
> End If
> End Sub
> End Module
> uses
> > the Part Master.
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
I would suggest trying to Type cast the EpiGUID, like this instead of using the actual named control :
Dim eucSales As EpiUltraCombo = CType(csm.GetNativeControlReference("5483cdef-3049-4705-b597-28ae93bc7fdf"), EpiUltraCombo)
I had the same issue when I tried to use EpiUltraCombos, but I was attaching an adapterCombo to them such as UD01AdapterCombo. I was then trying to use the ComboBox and I would get that error.
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of John Driggers
Sent: Wednesday, March 21, 2012 7:27 AM
I don't see anything that jumps out as wrong. Are you sure that name matches your control?
> Here is the code
> Imports System
> Imports System.Data
> Module Script
> End Sub
> End Sub
> LoadUDCombos()
> End Sub
> '// Load UD02 Combo
> If recSelected Then
> End If
> End Sub
> End Module
> exist in the last few lines.
> terribly long, post it and we can probably help more.
> > Master that
> uses
> *John Driggers*
> **:: 904.404.9233*
> *:: waffqle@...*
> *:: NO FAXES*
*John Driggers*
**:: 904.404.9233*
*:: waffqle@...*
*:: NO FAXES*
