Vantage 8.03.409C: Customization error
I removed the listpanel and just relocated the labels and Textboxes off of the form (setting the x to -500). So today I will bring them back in and see what I get. Thanks for the idea.
But it is strange that I get UltraGrid errors. It may be from the listpanel. . . It is also strange that I have four grids that I added and three of them I set properties like GroupBy and I get three errors in a row.
It will be a GREAT debug, in the looses sense of the word, day!!
Dan Godfrey
(805) 389-1935 x 251
From: vantage@yahoogroups.com [mailto:vantage@yahoogroups.com] On Behalf Of Jose Gomez
Sent: Friday, August 30, 2013 6:40 AM
To: Vantage
Subject: Re: [Vantage] Vantage 8.03.409C: Customization error
Did you hide / remove the native controls and Panels that came with the form? If so that might be your problem I've ran into an issue before where if you hide all the native Panels when the form loads there is something in the code that sets focus and then that piece of code fails.
If that's not your issue then I would comment out all the code in the InitializeCustom code and see if the error goes away if ti does, then uncomment one line at a time to find the culprit.
If you have visual studio and are in 9xx you can use it to debug the customization.
oh never mind I see you are in 8x. do the comment thing and let me know if it works.
Thanks!
*Jose C Gomez*
*Software Engineer*
*T: 904.469.1524 mobile
E: jose@...
http://www.josecgomez.com
<http://www.usdoingstuff.com>
On Thu, Aug 29, 2013 at 5:52 PM, Dan Godfrey <dgodfrey@...> wrote:
> I really dislike whatever Yahoo did to the website. It allowed me to
> enter a post, After while of searching how to post. It then removed
> all of the paragraphing or formating of the message that I entered. so
> here is the text of my message in a bit of a neater form.
> I hijacked the UD01Form to create a new form. It acts like a dashboard
> for the most part, but I have to do some manipulation of the data as
> well as have a summary grid of the data. So I added 4 grids (Bookings,
> Shipments, Backlog, and the Summary grid). Everything was working
> great. I was almost done with all of the code and THEN I saved it and
> rebooted Vantage. When I opened up the form, I got three error
> messages all saying the same thing. I had compiled and saved many times and then this happens.
> What I do with the grids are a DynamicQueryAdapter.GetByID to add the
> column Names to the grids. this is done in the FormLoad function. I
> set some column masking, sizing, Column renaming . I also set the
> group By and sort by. All minimal stuff to initialize the grids. I
> can't figure out what is the problem.
> There are no personalizations on the customization. There is no column
> name called "Key". I commented out the InitializeGrids function and I
> still get the errors.
> Does anyone have a clue or idea? I am open to anything, BUT redoing
> the customization.
> Error Detail
> Key not found
> Parameter name: key
> Stack Trace
> at Infragistics.Shared.KeyedSubObjectsCollectionBase.GetItem(String
> key) at
> Infragistics.Win.UltraWinGrid.ColumnsCollection.get_Item(String key)
> at Epicor.Mfg.UI.FrameWork.EpiUltraGrid.LayoutLoadFromXml(XmlDocument
> gridLayout)
> CONFIDENTIALITY NOTICE: The data attached/enclosed may contain
> information (including technology and technical data) which is subject to the U.S.
> International Traffic in Arms Regulations (ITAR) or Export
> Administration Regulations (EAR). This information may not be
> exported, released, or disclosed to foreign persons either inside or
> outside the United States without first obtaining the proper U.S.
> export license or written authorization. In addition, the information
> and articles described herein are either patented or proprietary, and
> the copying or reproduction thereof is prohibited without ADVANCED
> Motion Controls prior written consent. If you are not the intended
> recipient (or have received this e-mail in error), please notify the
> sender immediately and destroy this e-mail. Any unauthorized copying,
> disclosure or distribution of the material in this e-mail is strictly forbidden. Thank you for your compliance.
I hijacked the UD01Form to create a new form.  It acts like a dashboard for the most part, but I have to do some manipulation of the data as well as have a summary grid of the data.  So I added 4 grids (Bookings, Shipments, Backlog, and the Summary grid).  Everything was working great.  I was almost done with all of the code and THEN I saved it and rebooted Vantage.  When I opened up the form, I got three error messages all saying the same thing.  I had compiled and saved many times and then this happens. What I do with the grids are a DynamicQueryAdapter.GetByID to add the column Names to the grids.  this is done in the FormLoad function.  I set some column masking, sizing, Column renaming.  I also set the group By and sort by.  All minimal stuff to initialize the grids. I can't figure out what is the problem.  There are no personalizations on the customization.  There is no column name called "Key".  I commented out the InitializeGrids function and I still get the errors. Does anyone have a clue or idea?  I am open to anything, BUT redoing the customization. Error Detail ============ Key not found Parameter name: key Stack Trace ===========    at Infragistics.Shared.KeyedSubObjectsCollectionBase.GetItem(String key)    at Infragistics.Win.UltraWinGrid.ColumnsCollection.get_Item(String key)    at Epicor.Mfg.UI.FrameWork.EpiUltraGr
I really dislike whatever Yahoo did to the website. It allowed me to enter a post, After while of searching how to post. It then removed all of the paragraphing or formating of the message that I entered. so here is the text of my message in a bit of a neater form.
What I do with the grids are a DynamicQueryAdapter.GetByID to add the column Names to the grids. this is done in the FormLoad function. I set some column masking, sizing, Column renaming . I also set the group By and sort by. All minimal stuff to initialize the grids. I can't figure out what is the problem.
Error Detail
Key not found
Parameter name: key
Stack Trace
at Epicor.Mfg.UI.FrameWork.EpiUltraGrid.LayoutLoadFromXml(XmlDocument gridLayout)
CONFIDENTIALITY NOTICE: The data attached/enclosed may contain information (including technology and technical data) which is subject to the U.S. International Traffic in Arms Regulations (ITAR) or Export Administration Regulations (EAR). This information may not be exported, released, or disclosed to foreign persons either inside or outside the United States without first obtaining the proper U.S. export license or written authorization. In addition, the information and articles described herein are either patented or proprietary, and the copying or reproduction thereof is prohibited without ADVANCED Motion Controls prior written consent. If you are not the intended recipient (or have received this e-mail in error), please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden. Thank you for your compliance.
customization.
it works.
Thanks!
*Jose C Gomez*
*Software Engineer*
E: jose@...
> is the problem.
> get the errors.
> customization.
> Error Detail
> Key not found
> Parameter name: key
> Stack Trace
> gridLayout)
