Part Tracker Customization error - Object reference not set to an instance of an object
I have narrowed down the line that is causing this error but I don’t know enough to fix it, hope someone can help
This is the code, The line between the messagebox’s is the current problem, I am sure the next line will have the same issue
public class Script
// ** Wizard Insert Location - Do Not Remove ‘Begin/End Wizard Added Module Level Variables’ Comments! **
private EpiDataView edvPart;
//private EpiDataView edvPartWhse;
	this.btnPrintLabels.Click += new System.EventHandler(this.btnPrintLabels_Click);
	EpiDataView edvPart = ((EpiDataView)(oTrans.EpiDataViews["Part"]));
	//EpiDataView edvPartWhse = ((EpiDataView)(oTrans.EpiDataViews["PartWhse"]));
	this.btnPrintLabels.Click -= new System.EventHandler(this.btnPrintLabels_Click);
	// Begin Custom Code Disposal
	// End Custom Code Disposal
	this.edvPart = null;
	//this.edvPartWhse = null;
private void btnPrintLabels_Click(object sender, System.EventArgs args)
MessageBox.Show(“btnPrintLabels_Click”);
string partNum = edvPart.dataView[edvPart.Row][“PartNum”].ToString();
MessageBox.Show(partNum);
string descr = edvPart.dataView[edvPart.Row][“PartDescription”].ToString();
//string location = edvPartWhse.dataView[edvPartWhse.Row][“PrimBinNum”].ToString();
string mtlAnalysisCode = edvPart.dataView[edvPart.Row][“MtlAnalysisCode”].ToString();
	string filelocation = string.Empty;
	string outputLine = string.Empty;
	EpiNumericEditor nbrLblQty = (EpiNumericEditor)csm.GetNativeControlReference("58bf5c04-f44b-4ae3-82b7-dba3489c85c6");
	decimal completedQty = System.Convert.ToDecimal(nbrLblQty.Value);
	if(completedQty > 0)
		for (int a = 1; a <= completedQty; a++)
			filelocation = @"\\server\folder\";
			int secs = System.Convert.ToInt32(DateTime.Now.TimeOfDay.TotalSeconds * 100);
			filelocation = filelocation + "P" + secs.ToString() + a.ToString() + ".LBL";
			outputLine = "^XA" + Environment.NewLine;
			if (completedQty > 1)
				if (a < completedQty)
					outputLine = outputLine + "^MMT" + Environment.NewLine;
				else
					outputLine = outputLine + "^MMC" + Environment.NewLine;
			else
			outputLine = outputLine + "^FO20,20^ADN,36,20^FD" +  partNum + "^FS" + Environment.NewLine;
			outputLine = outputLine + "^FO290,15^B3N,N,50,N,N^FD" + partNum + "^FS" + Environment.NewLine;
			outputLine = outputLine + "^FO20,75^ADN,28,10^FD" + descr + "^FS" + Environment.NewLine;
			outputLine = outputLine + "^FO20,115^ADN,28,10^FD" + mtlAnalysisCode  + "^FS" + Environment.NewLine;
			//outputLine = outputLine + "^FO20,165^ADN,36,20^FD" +  location + "^FS" + Environment.NewLine;
			//outputLine = outputLine + "^FO230,155^B3N,N,50,N,N^FD" + location + "^FS" + Environment.NewLine;
			outputLine = outputLine + "^XZ" + Environment.NewLine;
			using (var TCFile = new System.IO.StreamWriter(filelocation, true))
				TCFile.WriteLine(outputLine);
				TCFile.Close();
Hello Barry,
I can see that you declare a new EpiDataView edvPart = … in the InitializeCustomCode() Method. You don’t have to do that, just initialize it there:
Do you get the error when you first open the form? before any records are loaded?
I only get the error when I click the Print Labels button.
I’m defnintely not an expert when it comes to this… could it have something to do with the button click code is being written when the form is loaded and there is no part record yet selected?
Thank you stoyanlevakov, that was the problem
