Good Day Greg:
CAN BE harmful - so run on test account first. If it fails, you will
have almost as many errors as before and they are different errors. To
test, run it in report mode before and after running in Update mode. If
patched or not depends on Version - might be worth a call to helpline
but they will probably ask you to run it anyway in TEST.
Len
Of Greg Payne
Sent: Wednesday, October 17, 2012 10:37 AM
Subject: [Vantage] PartWhse - PartQty DemandQty difference - conversion
6430
Will conversion 6430 sync PartQty to PartWhse? I have correct demand in
PartQty and incorrect in PartWhse.
Is there any harm in running?
Are there other common conversions I should be prepared to run. I
scoured the list and found lots of references to 6430 and 7195.
Greg Payne
CONFIDENTIALITY NOTICE
The information contained in this communication, including attachments,
is privileged and confidential. It is intended only for the exclusive
use of the addressee. If the reader of this message is not the intended
recipient, or the employee or agent responsible for delivering it to the
intended recipient, you are hereby notified that any dissemination,
distribution or copying of this communication is strictly prohibited. If
you have received this communication in error, please notify us at
727-578-6280 and immediately delete the communication.
"This (document/presentation) may contain technical data as defined in
the International Traffic In Arms Regulations (ITAR) 22 CFR 120.10.
Export of this material is restricted by the Arms Export Control Act (22
U.S.C. 2751 et seq.) and may not be exported to foreign persons without
prior approval form the U.S. Department of State."
This e-mail and any attachments may contain proprietary and/or confidential information. If you are not the intended recipient, please notify the sender immediately by reply e-mail or at 410-472-2900 and then delete the message without using, disseminating, or copying this message or any portion thereof. With e-mail communications you are urged to protect against viruses.
Len
Of Greg Payne
6430
Greg Payne
