I’ve got a complicated BAQ that won’t work with filtering, needs parameters. My users would like this as an embedded dashboard. They would prefer not to have to enter the parameters when the dashboard BAQ is run. What is the best way to do this currently?
Ways I know of:
Make a simpler BAQ with no parameters, that can be filtered via dashboard browse. Add that to dashboard as a tracker, then publish the results and use them as parameters for the main BAQ. Each parameter passed via dashboard browse needs its own BAQ. Eg for 3 parameters, 3 filtered BAQs and one main BAQ. On the dashboard, hide the simple BAQ trackers and only show the main BAQ results.
Use code/BPMs to pass parameters through eg the UDCode table. Join that table in the BAQ and limit results with criteria. Dashboard Pass Silent Parameters to BAQ - #16 by dkavvouras
Both are pretty complex… so before I dive in - Is there a simpler way to pass data from the screen to the embedded dashboard main BAQ? Thanks!
