Payroll - Direct Deposit
We use it and it actually works good for us with the exception
of the overtime calculation. We needed a custom program for
that. Direct deposit works well. It just outputs to a file and
the bank software takes it from there.
Paul Klinger wrote:
> Is there anyone out there processing payroll using vantage and also using
> the direct deposit feature? Generally, how does the whole process work?
> What kind of problems have been encountered? Was custom programming support
> needed?
> Any response will be helpful. We are looking at implementing direct
> deposit, but we are having problems with our bank's
> ability to read our file.
> Thanks.
> Paul Klinger
> Dauphin Graphic Machines
> 717-362-3243
> We no longer allow attachments to files. To access/share Report Files, please go to the following link: http://www.egroups.com/files/vantage/
> (Note: If this link does not work for you the first time you try it, go to www.egroups.com, login and be sure to save your password, choose My Groups, choose Vantage, then choose Files. If you save the password, the link above will work the next time you try it.)
We have been testing this and will go live in January. We encountered two problem areas: Vantage handles some benefit calculations differently than ADP, it seems that either ADP is wrong, or our payroll clerk at the time of signing-up with ADP, relayed the wrong information. The only other issue had to do with getting the Vantage direct deposit file converted to the format for the bank. From what I saw of other users, there banks were most cooperative in this. We (me) had to write a program to perform this conversion.
Sent: Thursday, November 30, 2000 03:12 PM
To: vantage@egroups.com
Subject: [Vantage] Payroll - Direct Deposit
needed?
Thanks.
Paul Klinger
717-362-3243
