I am trying to auto print preview once the MtlTags report form loads. I found this thread (Perform Click of Clear Tool with code - Yahoo Archive - Epicor User Help Forum ) that is similar, but I’m not sure how to call out the method.
MethodInfo mi = typeof(Erp.UI.Rpt.MtlTags.MtlTagsForm).GetMethod("OnClickPrintPreview",BindingFlags.NonPublic | BindingFlags.Instance);
mi.Invoke(MtlTagsForm, new object[] {});
niva5171
(Nick Vaughan)
July 13, 2018, 6:05pm
2
This is working code I have to print preview a BAQ report as PDF from a button:
private void preview_Click(object sender, System.EventArgs args)
string format2 = "PDF";
printpreview("p-notes2","P-NOTES2","Production Notes",format2);
private void printpreview(string BAQ, string report, string reportname,string format)
string agentID = "";
try
Session otSession = (Session)oTrans.Session;
//Set the workstationID
string workStation = Ice.Lib.Report.EpiReportFunctions.GetWorkStationID(otSession);
string userID = otSession.UserID;
//Get or Set the AgentID
using (var aSA = new SysAgentAdapter(oTrans))
oTrans.PushStatusText("Get System Agent Info", true);
aSA.BOConnect();
aSA.GetDefaultTaskAgentID(out agentID);
if (!string.IsNullOrEmpty(agentID)) { agentID = "SystemTaskAgent"; }
var baqR = WCFServiceSupport.CreateImpl<Ice.Proxy.Rpt.BAQReportImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.BAQReportSvcContract>.UriPath);
var dynamicReport = WCFServiceSupport.CreateImpl<Ice.Proxy.BO.DynamicReportImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.DynamicReportSvcContract>.UriPath);
var rptMonitor = WCFServiceSupport.CreateImpl<Ice.Proxy.BO.ReportMonitorImpl>((Session)oTrans.Session, Epicor.ServiceModel.Channels.ImplBase<Ice.Contracts.ReportMonitorSvcContract>.UriPath);
// GET DEFAULT REPORT PARAMETERS
var rptDs = dynamicReport.GetByID(report);
var baqRptDS = baqR.GetNewBAQReportParam(report);
baqRptDS.BAQReportParam[0].AutoAction="SSRSPREVIEW";
baqRptDS.BAQReportParam[0].WorkstationID=workStation;
baqRptDS.BAQReportParam[0].UserID=userID;
baqRptDS.BAQReportParam[0].SSRSRenderFormat = format;
baqRptDS.BAQReportParam[0].AttachmentType = format;
baqRptDS.BAQReportParam[0].BAQRptID=(report);
baqRptDS.BAQReportParam[0].ReportID=(report);
baqRptDS.BAQReportParam[0].Summary = false;
baqRptDS.BAQReportParam[0].ReportStyleNum = 1;
baqRptDS.BAQReportParam[0].BAQID=(BAQ);
baqRptDS.BAQReportParam[0].ReportTitle = reportname;
rptDs.AcceptChanges();
StringWriter writer = new StringWriter();
rptDs.WriteXml(writer);
baqRptDS.BAQReportParam[0].Filter1 = writer.ToString();
baqR.SubmitToAgent(baqRptDS, agentID, 0, 0,"Epicor.Mfg.UIRpt.BAQReport");
catch (Exception ex)
MessageBox.Show("An error occured trying to print report." + ex.Message);
This prints it in PDF format. Honestly, I do not know if this will translate to a normal report, but maybe you can tweak it for your situation???
