Physical Inventory - Epicor 905
Hi Adam,
>most of the tags (4 reams of paper worth) are useless.
In my case, I made a custom report style.
Each 8-1/2 x 11 sheet has 20 "tags", about 40 pages.
- Sorted by Bin location
(We only use about 20 blank tags, so one sheet for them).
The pages split up between a few people & they can just walk around the shop and count once.
>I really despise the idea of having
>to mark all of these tags as being returned.
I don't know of any way around count tag entry.
I have one more custom report style to list the variances - again sorted by bin location.
- recount
- tag entry
- post
--- In vantage@yahoogroups.com, "Adam" <paladinxc@...> wrote:
> Is there, or can you think of, a way to run with blank tags only? Our biggest issues is that our bins in the warehouse are so out of whack with Epicor that most of the tags (4 reams of paper worth) are useless. I really despise the idea of having to mark all of these tags as being returned. Also, the amount of paper required to use duplicate tags, and the extra work involved in colating different paper colors to make management happy.
> Thank you for the assisance,
> Adam
> --- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@> wrote:
> > Hi Adam,
> > Below are generic instructions for a full physical. These are based on a tech tip Epicor sent me.
> > The steps are different in E9 that in V8, but I didn't find it any harder.
> > Sounds like label/tags will be the biggest issues for you?
> > I was able to finally get what I needed wit a custom report style.
> > 1.Initialize Full Physical Inventory
> > oInventory Management > General Operations > Initialize Full Physical Inventory Process
> > oSelect the Warehouse(s) that you want to include, and your other parameters as well.
> > oProcess
> > Note: The process above will create the Count Period, Schedule and Group automatically,
> > so it is unnecessary to create those manually as you would with a Cycle Count.
> > 2.Cycle Count Maintenance
> > oInventory Management > General Operations > Count Cycle Maintenance
> > oPress Cycle, Check Include Physical Inventory, and press Search.
> > oSelect the Cycle Actions > Generate Tags, choose parameters and press Generate
> > Tags again.
> > oActions > Start Count Sequence (See Note)
> > Note: According to help, the Initialize Full Physical Inventory process should start the count sequence for you. At this time, however, it does not.
> > 3.Count Tag Entry
> > oInventory Management > General Operations > Count Tag Entry
> > oSearch for and select your Cycle
> > oEnter your Tags, making sure to account for activity.
> > 4.When all tags are entered or voided, return to Cycle Count Maintenance
> > oInventory Management > General Operations > Cycle Count Maintenance
> > oActions > Count Variance Calculation/Report
> > oReview the report
> > oActions > Post Counts
> > --- In vantage@yahoogroups.com, "Adam" <paladinxc@> wrote:
> > > Question to the group.
> > > Being very familiar with Vantage 8.03, and working for a company coming from Vantage 6, we are discovering that our Physical Inventory process is not possible, or more difficult, in 9.05.
> > > First, we use pre-ordered, pre-printed, carbon duplicate tags. In Vantage, we were able to generate blank tags only, and starting at a certain number. Now, it appears we must use generated tags on a warehouse/bin level. This would be fine, if our people knew how to put things back/stock them correctly. Physical inventory is where we fix these issues.
> > > Is there a way or workaround that can work like the old physical/generate tags options? Cycle count that includes all parts? Something?
> > > Any help is appreciated.
> > > Adam Long
Adam Long
Hi Adam,
oProcess
Tags again.
3.Count Tag Entry
oReview the report
> Adam Long
Adam
--- In vantage@yahoogroups.com, "cooner_55421" <cooner_55421@...> wrote:
> Hi Adam,
> oProcess
> Tags again.
> 3.Count Tag Entry
> oReview the report
> > Adam Long
