Sadly, noone here knows a whole lot about Report Builder. I have created
a bunch of very very simple reports, but that is it. :(
Michelle Von Bokern
Office Manager
Advance Engineering Co.
PH: 630-628-3445
FAX: 630-628-3449
mvonbokern@...
vantage@yahoogroups.com [mailto:
vantage@yahoogroups.com] On Behalf
Of Paul H. Smith
Sent: Wednesday, October 12, 2005 1:22 PM
To:
Subject: RE: [Vantage] Physical Inventory Generated Tags
I was just told that the report we use is a report builder report.
Please
keep in mind that whether they are Report builder reports or Crystal
reports, you would have to know how to add them to the vantage menu and
Crystal would need the ODBC driver setup. Not sure if the report I use
will
help you. Is anyone in your IT dept able to create reports?
vantage@yahoogroups.com]On
Behalf Of
Michelle VonBokern
Sent: Wednesday, October 12, 2005 12:07 PM
To:
Oohh Paul that would be wonderful. Do you guys just do Qty adjustments
to do inventory then?
Michelle Von Bokern
Office Manager
PH: 630-628-3445
FAX: 630-628-3449
mvonbokern@...
Behalf
Of Paul H. Smith
Sent: Wednesday, October 12, 2005 10:53 AM
To:
Let me see what I can do about sharing this report. To answer you
question
it is not printed using the count entry screen. It is printed in
materials
management, inventory management, reports. It was placed there by our
IT
dept.
[Paul H. Smith]
Behalf
Of
Michelle VonBokern
Sent: Wednesday, October 12, 2005 11:42 AM
To:
Paul, is this crystal report something you would be willing to
share?
Do you still print them from the Count entry screen? I would be very
interested if you are willing to share. I absolutely hate the tags
we
are using now, there are only a few tags per sheet.
Michelle Von Bokern
Office Manager
mvonbokern@...
Behalf
Of Paul H. Smith
Sent: Wednesday, October 12, 2005 10:22 AM
To:
We also do not use the tags printed by the system. We generate our
tags
via
crystal report. Our tags are printed on 8.5 x 11 sheets of paper,
this
gets
21 tag numbers per sheet. Each tag number has all the information
for
our
count teams to conduct inventory ( location, part number,
description,
and
blank columns for the counter\recorder to enter information i.e the
counts
as well as counted by, date counted, and time counted. Works great
for
us.
Behalf Of
Butch Menge
Sent: Wednesday, October 12, 2005 11:13 AM
To:
When we do our inventory, we don't print tags from the system. We
use
off-the-shelf carbon-paper tags and then enter them into the
system
with
the tag number that is on the paper. Works out ok but the
counters
have
to write all the part numbers, description, location and count on
the
tags. We do the WIP counts in an Access database (download the
jobs
and
print out count sheets).
Butch
Behalf
Of Rick Gors
Sent: Wednesday, October 12, 2005 7:10 AM
To:
I use a Report Builder report format and I print about 19 or so
lines
on
a
page to count with. I don't use serial numbers, but I use Lot
numbers,
which are accommodated. It is a very simple layout that works for
us.
No
bar codes either. But the thought of thousands of pages printing
out
was
way beyond my idea of a count sheet system.
Hope this helps...
Rick G
Behalf Of
amfabllc
Sent: Tuesday, October 11, 2005 6:06 PM
To:
Subject: [Vantage] Physical Inventory Generated Tags
Vantage version 5.0:
Currently, if you 'generate tags' in count entry, you are
suppose
purchase 2 part tags to be printed 3 per sheet on a dot matrix
printer
from Epicor. (I just generated tags Training, we have over 4400
tags,
which would be 1400 dot matrix pages).
Has anyone come up with something printed on a laser printer -
possibly making changes to the Crystal form to a half or full
sheet??
We should be able to purchase 2 color paper (ie. white prints,
then
identical pink carbonized prints out). Even if you had to have
someone staple the white and pink pages together with an
electric
stapler, it wouldn't be any worse than someone having to rip the
dot
matrix tags apart, and laser prints much faster, less chance of
a
jam,
etc.
I printed some test tags on regular paper (laser) and tried to
scan
the tag number into Vantage so I wouldn't have to manually enter
the
9
digit tag, but the barcode reader did not read it (it would read
some,
but not others). It would be nice to scan the tag# so Vantage
can
take you to that record, then tab a few times to qty. Do I need
to
change something on the Crystal form?
You guys have such outstanding ideas, thought I would pick your
brain...has anyone tried anything like this?
Ann Rohyans
AMFAB
574-264-4431
amfab@...
Useful links for the Yahoo!Groups Vantage Board are: ( Note: You
must
have already linked your email address to a yahoo id to enable
access.
(1) To access the Files Section of our Yahoo!Group for Report
Builder
http://groups.yahoo.com/group/vantage/files/>
SPONSORED LINKS
Manufacturing software
http://groups.yahoo.com/gads?t=ms&k=Manufacturing+software&w1=Manufactu
ring+software&w2=Membership+database+software&w3=Database+mortgage+softw
are&w4=Pda+database+software&w5=Database+management+software&w6=Database
+marketing+software&c=6&s=188&.sig=OG5F3819UOUOg63i0bu6kA>
Membership database software
http://groups.yahoo.com/gads?t=ms&k=Membership+database+software&w1=Man
ufacturing+software&w2=Membership+database+software&w3=Database+mortgage
+software&w4=Pda+database+software&w5=Database+management+software&w6=Da
tabase+marketing+software&c=6&s=188&.sig=N5BGdur84p-jyuOomcQdbQ>
Database mortgage software
http://groups.yahoo.com/gads?t=ms&k=Database+mortgage+software&w1=Manuf
acturing+software&w2=Membership+database+software&w3=Database+mortgage+s
oftware&w4=Pda+database+software&w5=Database+management+software&w6=Data
base+marketing+software&c=6&s=188&.sig=8rvcSQnCqJhTCZu-0Si39A>
Pda database software
http://groups.yahoo.com/gads?t=ms&k=Pda+database+software&w1=Manufactur
ing+software&w2=Membership+database+software&w3=Database+mortgage+softwa
re&w4=Pda+database+software&w5=Database+management+software&w6=Database+
marketing+software&c=6&s=188&.sig=u3KQrTRPAQfsWIT39aHDkg>
Database management software
http://groups.yahoo.com/gads?t=ms&k=Database+management+software&w1=Man
tabase+marketing+software&c=6&s=188&.sig=R3CF3ODPY4gwjDZjykQYvw>
Database marketing software
http://groups.yahoo.com/gads?t=ms&k=Database+marketing+software&w1=Manu
facturing+software&w2=Membership+database+software&w3=Database+mortgage+
software&w4=Pda+database+software&w5=Database+management+software&w6=Dat
abase+marketing+software&c=6&s=188&.sig=lmBkRUiBtvHI1u5dkymDcw>
YAHOO! GROUPS LINKS
* Visit your group "vantage
http://groups.yahoo.com/group/vantage> " on the web.
<mailto:
vantage-unsubscribe@yahoogroups.com?subject=Unsubscribe>
* Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service <
http://docs.yahoo.com/info/terms/> .
must
access.
Builder
and
YAHOO! GROUPS LINKS
a.. Visit your group "vantage" on the web.
b.. To unsubscribe from this group, send an email to:
c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
must
access.
Builder
Yahoo! Groups Links
must
have already linked your email address to a yahoo id to enable access.
Builder
and
SPONSORED LINKS Manufacturing software Membership database software
Pda database software Database management software Database
marketing software
YAHOO! GROUPS LINKS
Service.
Yahoo! Groups Links
and
YAHOO! GROUPS LINKS
Service.
Yahoo! Groups Links
