We have so many change PO suggestions that our buyer does not even review them. He says it is too time consuming.
I looked at them myself and found that most of the suggestions were due to falling below the minimum on hand qty, which we typically ignore.
The problem is that some of the suggestions truly require action and we are sometimes late on orders because we ignore the suggestions.
I have tried to filter the suggestions in attempt to find the ones that are critical to no avail.
What I really need is a field that I exists in Time Phase called ExpediteReason. Where does this come from? I suspect it's not a data field but the result of a calculation within Epicor's Time Phase screen.
Is there any way to get at this field in a BAQ with SuggestPOChange data?
thanks in advance
randy weber
thanks in advance
randy weber
