PO Entry -> Receipt Entry (via Context Menu)
This probably has an answer right under my nose and I’m overthinking it. But a user requested that I added a context menu on PO Entry that opens up Receipt Entry.
I created the context menu item, but it looks like the PO Num field on Receipt Entry is not receiving the passed po number.
A user in this thread mentions a packing slip is also required, but I’m not sure that’s true in this case entirely? You can still load info from the PO #, and then pull the packing slip when done manually.
Looking for suggestions.
Hi Jacob! Try this thread :slight_smile:
