Context Menu Maintenance Not Loading Data
Hi there, I tried to add a context menu maintenance for PO Number so that it can be opened with Receipt Entry. I have added the item to the context menu maintenance and it does show up.
When I right click on a PO Number, Open With, Receipt Entry, it will load the receipt entry form but it will be blank and not load the PO Number. Usually it will load the number with it, any ideas? Would I need to use processcaller instead?
Thank you!
Elvin
Receipt Entry also requires the Packing Slip. I do not think you can have just the PO Number open the screen up.
