Thanks. Actually, we tested this with jobs and it worked as expected -
we could specify a different warehouse for the job, and the job
inventory receipt went to the chosen warehouse per the job. But trying
the same with a purchase order did not work.
Randy Weber
IT Manager
TLC Electronics, Inc.
651-287-2972
rweber@...
Of brychanwilliams
Sent: Tuesday, October 09, 2007 10:41 AM
Subject: [Vantage] Re: PO receipt does not default to selected warehouse
I don't know if this relevant, but I believe this is the case on
jobs. E.g. where you create a job for a part number for stock. You
want to receive it to a different warehouse than what is associated
with the part etc.
Randy Weber
IT Manager
651-287-2972
rweber@...
Of brychanwilliams
with the part etc.
>as
> Vantage 6.10.525
> We're trying something new (to us) and it does not appear to work
> the Vantage help documentation suggests. We want to cause a part tobe
> received into a warehouse other than the default warehouse for thepart.
>since he
> I entered a PO release and choose a different warehouse for the
> Line/Release. When I did a Receipt Entry, for the line/release, the
> default warehouse shows up instead of the one I chose on the PO.
> Vantage is looking into it, but told me to upgrade to 6.10.542
> was unable to re-create the problem. I highly doubt that thisfeature
> would have been failing all this time since it's obvious in thehelp
> screen that the receipt goes first to the PO's warehouse.[Non-text portions of this message have been removed]
> Thanks in advance.
> Randy Weber
