PO Suggestion created without demand
We see a purchase order suggestion for 4 units, but there is no associated demand. Do you have any insights on why the PO suggestion was generated without demand?
I’ll suggest you access the log file and review the description of why it’s creating a PO Suggestions. With these screens only it gets difficult to review the root cause.
I am not sure we are using on cloud. Log file path not mentioned in the Generate suggestion screen.
Ok if you are cloud, run mrp/po suggestions just for that part, at the log name, change it so you can identify it. Once you execute the process, the log goes to Server File Download menu. From there you can pick the folder location and download the txt file.
Is warehouse MAIN the source/feeder for any other warehouses? If so, is there any demand/forecast/etc there?
What is your min stock qty (as opposed to Min order qty)… if the min stock qty is also set to 4, then that is a demand since your current stock qty is less than 4.
No forecast entry or demand
good point…didn’t think of that… :roll_eyes:
There is no demand for this part. We do not have any orders.Even though min on hand and safety stock is 0
Right, this takes a couple minutes and should not interrupt many people’s work (probably no one will notice).
No need to go on the hunt. Let the log tell you.
Min stock is set to 0
